Question about Samsung 52X IDE DELL BLACK BULK.CDROM (Optional Black FDD and CDRW) (SC152LEBBAEBB) CD-ROM Drive
Bootmgr is compressed how to decompress - Samsung 52X IDE DELL BLACK BULK.CDROM (Optional Black FDD and CDRW) (SC152LEBBAEBB) CD-ROM Drive
The Windows operating system allows you to compress the files on your drive to conserve disk space.
In some situations, this compression process will compress files required for the operating system to boot.
Files that are compressed must be decompressed prior to execution.
Since the operating system has not loaded, boot files cannot yet be decompressed.
In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear.
An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD.
Press a random key on your keyboard once you see the "Press any key..." message.
This interrupts booting from the hard drive and forces a boot from the Windows DVD.
Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below.
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx
File Compression and Decompression
Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog.
This opens a file browser on your screen.
Click the "Computer" icon, which is located on the left hand side of the screen.
This displays an icon for your disk drive.
Right-click your hard drive, and click "Properties.
" This opens a Local Disk Properties dialog.
Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button.
Select the "X" icon to close the file browser window.
This takes you back to the Install Windows dialog.
Press the "X" icon at the corner of the Install Windows dialog.
This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Nov 26, 2013 | Acer Extensa 5620 Notebook PC
Bagaimana mencari bootmgr hp mini
Step 1:
gogle translated
how to find bootmgr hp mini
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
it will work 100% only if you prompt at the same order Hope this helps. BOOTMGR Is Compressed b> The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Feb 22, 2013 | Computers & Internet
Bootmgr is compressed in my presario cq40
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 21, 2013 | HP Compaq Presario CQ40-330TU
b>
Jan 21, 2013 | Compaq nl284la - Presario Cq40-320la...
BOOTMGR is compressed
then type in exit
Jan 16, 2013 | Dell Computers & Internet
My bootmgr is copressed.
then type in exit
b>
Jan 15, 2013 | Dell Mini 910 Netbook
b>
Jan 09, 2013 | Microsoft Windows 7 Ultimate 32bit
I have a acer aspire 5000 and when i turn it on it says bootmgr is compressed, press ctl+alt+del to restart but it wont restart
b>
Jan 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Computer error on startup .. Fkymo is compressed .. How do I get out from the screen? This is a dell dimension 2400
I think BootMGR is compressed..you need to decompress your Hard Drive.
To do that, you Boot Windows CD, Go in Repair option in your computer, and then load drivers
By there, you go back until you find computer, and then you decompress everything.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
This method repairs the boot manager, leaving the rest of the partition compressed or uncompressed as before. This method also has the advantage of being much quicker than some methods which involve decompressing the entire partition, plus if much of the drive was compressed, a full decompression wouldn't be possible if disk space was low.
1....Boot off the relevant DVD for your operating system and press a key if/when you are prompted.
2....Select a language, a time, a currency, a keyboard or an input method, and then click "Next".
3....Click "Repair your computer".
4....Click the operating system that you want to repair and then click "Next" (usually on C:).
5....From the "System Recovery Options" menu, choose "Command Prompt".
6....Type the following commands exactly as written below, pressing return after each one:
bootrec /fixmbr
bootrec /fixboot
bootrec /rebuildbcd
exit
7.... Reboot your PC and test.
Dec 13, 2010 | Acer Aspire 5720 Notebook
Samsung 52X IDE DELL BLACK BULK.CDROM (Optional Black FDD and CDRW) (SC152LEBBAEBB) CD-ROM Drive Logo
23 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
