My Maytag washer leaks badly around the bottom on the spin cycle
It looks to me that the pump that is supposed to pump the water though the discharge line is not working and all the water is going down through it onto the floor. The model no. is MAV7650AWW. The tub itself seems to be okay and not leaking. Where would a find a replacement part or should washer be replaced?
  • BEARBURR30 Jan 26, 2009
    yesterday, i was washing a large load and I think I might have overloaded it just a bit, by the way I have a older model Maytag 2-speed 120V washing machine and while washing I was checking on it and i started hearing this noise coming out of loud wrenching noise as it was going into the spin cycle and then I saw smoke and smelled a burnt rubber smell and opened the lid to see that the water was not draining out of the "tub" not sure if that is the correct term, I manually drained the water out and tried again and the noise continued there was no smoke but the burnt rubber smell was apparent and no water was draining out of the "tub". what can I do? what has happened? water has been leaking out from the bottom of the washer during spin cycle too and I just hadn't paid too much attention to it until now.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    you say''and all the water is going down through it onto the floor''.if the pump it self is bad water wont be leaking from above it.this washers are good for tub leaks,also the tub to pump hose can crack.and very frquently the pumps go bad.....if your washer is in good shape other wise yes if pump i would replace.shop around on line for the cheapest price.you will find it by model # once you have that part# the google the part# and may give you more options.also i have seen new parts very reasonable on Ebay.ps if you drain water[may be with a bucket]you can tip your washer back against the wall and inspect all three pullys,belt.the motor pully goes bad and belts wear so if ordering parts may just want to check those out also.hope this helps God bless ,tom
Sounds like you might need a new pump belt. They are inexpensive and easy to replace. Unplug the washer and with the water out tilt it back so that you can see the bottom. You have a main drive belt that goes from the motor to the big pulley in the middle. There should be a second belt that goes from the motor to a smaller pulley which is the pump. Make sure that this pulley turns freely in both directions. One direction is agitate and the other is discharge. If it does and your belt is loose a new belt might do the trick.
If the pulley does not move freely take off the front panel, two philip screws about 3 inches up from the bottom of the front panel. Inspect the pump. One time I found a scouring pad in the pump!! If after inspection the pump still does not move freely you may need to purchase a new pump. Find the part number and check out prices on-line. The pump is relatively easy to replace. Good Luck
Posted on Feb 07, 2009
My washer is leaking bad and does not spin all the water out
there may be a blockage in the waste water pump had a similar problem with a beko there was a rubber band wraped around the outlet fan
Jan 23, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
1,594 people viewed this question
Top Washing Machines Experts
