Question about Onkyo TX-SR500 Receiver
Recording from other sources
I am able to connect a CD player, a turntable, a cassette deck and an 8 track player to my TX-SR500 Onkyo receiver and to play all of them. However I am unable to record music to my CDs from any of these sources. What do I need to do to record using analog system? I was able to record from these sources in the past using a splitter. At that time my sound system was coordinated with my television. Currently, my sound system is independent of my TV and is at a different location. Please advise. Thank you! William Resser
  • William Resser Aug 07, 2007
    Your answer is too technical for me. I need to have a more simplified and clearer explanation.
    Thank you.
    William Resser
    President:
  • 3,130 Answers
The tape outputs is what you need to use. If there is not output on those tape outs, you have a preamp problem I'm afraid. I have seen these go out in the past when someone hooks up an output to the tape outputs and blows out the preamp IC. Good Luck
Posted on Jul 17, 2007
  • Larry  Dillon
    Larry Dillon Aug 07, 2007
    How much clearer can I be. Have the unit serviced if you do not understand the terms please.
Why does the volume fluctuate when playing any connected equipment to my receiver?
You are describing one of the inherent problems in assembling various pieces of equipment into a complete system. Unless your Kenwood receiver has some provision for equalizing the various input levels, you will just have to adjust each one manually.
Dec 28, 2013 | Audio Players & Recorders
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
How and am i able to connect a hdmi dvd player to
You don't.
Use whatever digital or analog audio outputs and S-video or composite video outputs that are provided on your source devices.
Feb 27, 2010 | Onkyo TX-SR500 Receiver
How to connect a turntable to Onkyo txsr 500
Just like most contemporary AV Receivers, there is no built-in Phono preamp in this unit so if your TT doesn't have one internally, you'll need to get an aftermarket Phono Preamp somewhere to PREamplify and frequency-balance the minute Phono Cartridge output to a useable Line Level you can send to any available Line Level input on the Receiver (CD, Aux, whatever) .
Feb 06, 2010 | Onkyo TX-SR500 Receiver
Trying to connect cable box....
You should be able to pick any open audio device unless it says pre-amp only. If your manual shows a connection for a CD player or similar device it should support the cable box.
Good luck and thanks for using FixYa
Mar 17, 2009 | Onkyo TX-SR500 Receiver
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Recording from various sources.
you are nuts, you must to use a computer with analog line input if you wanna record from analog sources to a digital media
Aug 19, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Receiver Logo
73 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
