Question about Bosch Dryers
Bosch WTL 5200 runs but the drying results are very poor
THE DRYER FUNCTIONS BUT THE CLOTHES DO NOT SUFFICIENTLY DRY, DESPITE THE FACT THAT I SELECT THE "VERY DRY" OPTION
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
johnychel
  • 796 Answers
SOURCE: bosch axxis 3510 dryer doesn't dry clothes
click here
this might help you trouble shoot
Posted on Jun 26, 2008
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
  • 686 Answers
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
The dryer is not tubbling the clothes is runs, gets hot inside but does not dry the clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 26, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
AEG Lavamat Washing Machine Issues
you need soda crystals or a good descaler/degreaser agent to clear out machine repeated washing on low temps will cause scummy build up in inner drum door seal area,causing smells and poor rinsing result,this could be why condenser dryer not working as needs clear passage for air and steam during dry phase.
Jun 02, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
77 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
