Question about Janome 6260QC Computerized Sewing Machine
Janome 6260 bobbin case sucks in fabric
Starting the fabric into needle area OR while in the middle of the fabric, the bobbin area starts to "take in/suck in" the fabric into the bobbin area. Serviced for this twice and problem cannot be duplicated in store during service. Doing a straight stitch only. It is intermittent. Bobbin case itself is extremely loose & store knows this when I bring it in. Aggravated! Thanks for help
  • 2 more comments
  • Gina Jan 22, 2013
    Thanks Debbi. Taking the machine to a 3rd different Janome dealer to look at. What a pain! thanks for your thoughts. Needle was changed and also the face plate where the needle is has been changed. No difference seen. Being intermittent problem makes it hard.
  • you said the problem can\'t be duplicated at the repair shop,, then sew on the machine till it suck the fabric into the bobbin area and then take it to the shop and then let them see for them selves what it\'s doing.. also always make sure to use the correct needle for the fabric being sewed.
  • are you lifting the presser foot all the way up before threading the machine? also make sure the top thread has not come off the thread take up lever
  • Gina Jan 23, 2013
    Thanks for your comments. My husband drops off the machine and I call the shop & explain in detail the problem is how I've had to deal with this at 2 diff. dealerships for Janome. I work goofy hours & hubby takes the machine to the shop enroute to his job. Yes the presser foot is up before threading it and the machine is threaded correctly and new needle and the bobbin area clear of lint too and bobbin installed correctly. I plan to take the machine myself to the 3rd Janome dealer soon.
  • Janome Master
  • 7,365 Answers
Try getting a new bobbin case
and use a different bobbin
change the needle
if these suggestions don't help then take the machine to a different
repair shop to have the machine checked
Posted on Jan 21, 2013
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
Zenqi
  • 208 Answers
SOURCE: The bobbin thread is bunching on the under side of
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Posted on Jul 11, 2009
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
Zenqi
  • 208 Answers
SOURCE: I have a Janome Mycompact
Unthread the machine. Set the upper thread tension to 5 and raise the presser foot. Rethread the machine. With the presser foot up, pull about 12" of the upper thread through the needle and make note of how much tension you feel. Lower the presser foot and you should feel the thread get very tight. Also, make sure that you are using good sewing machine thread and not hand quilting thread, upholstery thread or too heavy weight thread for the machine.
Posted on Aug 03, 2011
6260 HOW TO PUT BOBBIN CASE IN/
here is a link for a manual --it should have how to put the bobbin case in Instruction Manual Janome 6260
May 07, 2014 | Brother CS-8150 Computerized Sewing...
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
Hello my janome memorycraft 6500 will not sew. As soon as I lower the needle and start to sew the machine needle shudders and it jams.
try these suggestions
use a new needle
check to see if the top thread has come off the top thread take up lever
make sure the bobbin is turned the right way in the bobbin case
Mar 31, 2014 | Janome America Inc 6500P Memory Craft...
Cleaned out lint from bobbin area and bobbin thread is still bunching
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Jan 29, 2014 | Janome Sewing Machines
-what causes bird nest with the Janome Horizon 7700 sewing machine?
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
Apr 05, 2013 | Sewing Machines
My machine keeps clogging at the beginning of my sewing
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
Bobbin case problems
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
Sep 06, 2012 | Janome Sewing Machines
Janome mylock 204d needle keeps breaking when sewing a rolled hem on sequined fabric
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
May 16, 2012 | Janome Sewing Machines
Fabric stuck in hole where bobbin is underneath
Turn off the machine and remove the needle.
Lift the presser foot and remove the inner hoop and then the rest of the hoop.
Move the fabric to one side and cut the threads with a seam ripper.
Open the needle plate.
Remove the bobbin and bobbin case.
Clean away any thread or lint in this area.
You should repeat the last three steps routinely as lint and thread snips can accumulate in these area and cause mis-stitching.
Replace the bobbin case, bobbin and needle plate.
Use a new needle.
Jun 29, 2009 | Simplicity SE3 Computerized Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Janome 6260QC Computerized Sewing Machine Logo
115 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
