I'm after a replacement battery for a Tevion DVP 7011
Need battery
Where can I buy a remote control for my Tevion DVD recorder model DD1018 please?
GenuineCopies.tv - Replacement remote control for Tevion MD80857
www.genuinecopies.tv/remotes/brands/tevion/md80857.htm
Tevion MD80857. (Our category: DVD/Blu-ray Player Remote). Replacement Remote Control. No setup is required. All you need to do is to insert two batteries and it is ready to use. Long battery life; remote goes into very low power sleep mode when not in use. This remote works on the Tevion MD80857 only. You will be ... Missing: dd1018
televison & video can't find the component code for my tevion dvd ...
https://www.pete-maravich.com/q1029833_find_component_code_tevion_dvd_recor... Can't find the component code for my Tevion dvd recorder DD 1018. I want to replace the badly designed remote that came with this DVD recorder with the Sony universal remote RM-V210T but I can't find the component code anywhere. 4.0 stars ...
Remote Controls for Tevion
www.remote-controls-shop.com/catalogue/Tevion Remote Controls for Tevion. If you're looking for remote controls for Tevion, then you've come to the right place! We sell a wide range of remote controls for Tevion including both manufacturer's genuine original remotes and cost-effective replacements. Our database covers 253 models or parts for Tevion and our ...Missing: dd1018
Tevion DVD recorder DD1018 replacement remote Google Search
Mar 10, 2018 | Tevion Televison & Video
Tevion Dvd player won't read burned cd's or dvd's.
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Mar 10, 2013 | Televison & Video
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
Remote for philips model dvp 3050v/37 won't work
Remove old batteries and clean battery terminals with rubbing alcohol, allow seveal minutes to dry and replace the batteries with new ones.
Mar 07, 2012 | Televison & Video
Got a Tevion HDSR 600 free sat. on first instalation I got BBC 1 and 2 and channel 5, now i cant get them at all. I have sky in the other room and my tevion free sat runs from the same dish, sky tv is...
I have the exact same problem. After a week, I lost all reception on the 10733 H 22000 transponder and (from memory) 10823 which means no BBC1, BBC2 or CBEEBIES which are a must in my house. I have used another set-top box and received those channels without a problem, so it would seem that the Tevion decoder is at fault and needs returning to ALDI
Jun 21, 2011 | Televison & Video
How do you set the clock?
you can download the manual in pdf format here
http://www.retrevo.com/support/Kenwood-kDC-7011-Car-Receivers-manual/id/479ag518/t/2/
Aug 01, 2009 | Kenwood KDC-7011
Code kdc 7011
KENWOOD codes are NOT available for free from anywhere on the Internet.
Main Dealer or a Decoding Service only
Dec 20, 2008 | Kenwood KDC-7011
7011 code
Disconnect the battery. It should reset everything.
Unlock code
Call Kenwood with the SERIAL # of the unit. They will give you a code. Or contact the the supplier you got it from.
Feb 13, 2008 | Kenwood KDC-7011
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
