Question about Brother MFC 7420 All-In-One Laser Printer
My printer 7420 would not print the screen has the message job cancel cancel printing
  • 320 Answers
All you need to do is cancel the job and reprint it good luck
Posted on Jan 27, 2009
  • ServiceBama Sep 30, 2010
    I have the same problem, printing a large file accidentally, hit "Job Cancel" button, and now my display says:
    Job Cancel
    Cancel Printing
    I've pressed (I believe) every button on this unit with no effect. The only solution was to turn it off and back on. If figured someone should answer the question.
I entered a print job that I want to cancel. How do I cancel printing?
Click on the printer icon at the lower right hand corner of your screen.
This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
You will find the Cancel command in the menu.
Hope this helps.
Jul 21, 2011 | HP DeskJet 970cxi InkJet Printer
I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
Double left-click the name of your printer
Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
Apr 12, 2011 | HP Photosmart 3310 Printer
Can I pull up and print past history for faxes on my MFC-7420 ?
You can see your past history and can have its print if possible.
  • Insert your printer's USB cord into your computer's USB port.
  • Open your printer as a program by double clicking its icon that is located on your desktop (PC) or dashboard (Mac). This icon will pop up when your computer recognizes your printer via the USB cord.
  • Select the "Jobs" pull-down menu at the top of your screen while in your printer application.
  • Choose "Show Completed Jobs" from the "Jobs" pull-down menu
  • View every printer job completed or canceled.
Feb 18, 2011 | Brother MFC-7420 Laser Printer
How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
Dec 20, 2009 | HP Photosmart C7280 Laser Printer
I have the lexmark x1270. When a prit job is cancelled, it does not fully cancel and I cannot print the next job. I tried to uninstall it, but I couldn't because a message keeps coming up to wait for the...
Check the bottom right side of the PC screen.
If you see the printer icon there, double click it. That opens the print queue.
Highlight the print job that is causing the failure and delete it.
Dec 03, 2009 | Lexmark X1270 All-In-One InkJet Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Brother printer mfc-7420 will not print
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Jul 30, 2008 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
If no PROGRESS METER appears, you can access the document queue in this fashion:
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
134 people viewed this question
James Cagle
James Cagle
Jim Keysor
