Question about Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt
The until still heats up but produces no steam
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
For my singer electronic steam press esp2 can i use deironise water instead of distilled as i can not get any distilled water in any of the shops in my area.
You can try the deionized water but you may have trouble with it producing enough steam...water that is too pure may not produce steam well depending on the way it is heated.
If it does not produce enough steam just add a bit of salt to the water and it will work well.
heatman101
Aug 13, 2011 | Singer Electronic Steam Press
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Mar 26, 2009 | Rowenta Irons
Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt Logo
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
