Question about Dryers
I have a Kenmore 90 series Electric Dryer will run for a few minutes then stop
    Top Expert:
  • Dryers Master
  • 9,472 Answers
The motor is overheating. What is the model number?
Posted on Jan 20, 2013
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
Posted on May 22, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
I have a Kenmore 90 series dryer..this summer it started to go on all by it's self, if the door was closed it just would start..we had to keep the door open so it would not run. that lasted a few months...
Have you called themanfacturer re this problem you either have a faulty door switch or your timer is defective.I suggest you talk to manfacturer or a good applince repair there could be a defect in the dryer so ask them
Dec 18, 2009 | Kenmore 60172 Electric Commercial Dryer
My Kenmore 90 series dryer stopped running during cycle
IF YOU HAVE NOT CLEAN OUT THE LINT MOST PROVALY THE MOTOR IS FULL OF LINT AND IT GET HOT AND STOP.IT WENT IT COOLS DOWN IT STAR REPLACE THE MOTOR OR BUY A NEW 1 WILL CUST TO MUCH TO FIX.
Jan 24, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
Top Dryers Experts
