Question about Dryers
I have need to find the thermostat on the Kenmore 90 series Electric Dryer
It will turn on for a couple of minutes and then shut off makes noise when running
  • 5 more comments
  • Susan Doyle
    Susan Doyle Jan 20, 2013
    Model #110.60902990
  • Richard Roth
    Richard Roth Jan 20, 2013
    Is it heating while it is running? Exactly how long does it run and what kind of noise is it making?
  • Susan Doyle
    Yes it is working like normal and then 10 minutes it shuts off and the button makes a noise if you try to turn it on again
  • Susan Doyle
    but it won't start
  • Richard Roth
    Richard Roth Jan 21, 2013
    The motor is overheating and will need to be replaced. If it runs, then stops and will start again after a short while, the circuit is bad on the motor. Here is the part to order.http://bit.ly/T76v49
  • Susan Doyle
    Susan Doyle Jan 22, 2013
    I checked the part that you are saying and it comes back that it is not for a Kenmore Dryer and for 140.00 I might as well but a new one right?
  • Richard Roth
    Richard Roth Jan 22, 2013
    It is expensive I would replace it.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number?
Posted on Jan 20, 2013
IFIXALL
  • 868 Answers
SOURCE: Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
Posted on May 22, 2008
  • 91 Answers
SOURCE: dryer shuts off after 5 or 10 minutes
repl/ thermsitor if avaiable if not repl/ hi limit thermostat on top of ignitor
Posted on Jan 04, 2009
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 1122 Answers
SOURCE: Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
Posted on May 08, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
Kenmore series 90 electric dryer does not heat and shuts off after several minutes of use. Heating element is at 9 ohms, spec is 7-11.5 , thermal limit switch was open. I replaced thermal switch and...
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Feb 27, 2010 | Dryers
Kenmore 90 series electric dryer. Buzzez when you press the start. Sometimes it runs for a couple minutes then shuts off. is this the motor or a start capacitor?
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 07, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
May 20, 2009 | Kenmore Dryers
Dryer shuts off after 5 or 10 minutes
Dec 29, 2008 | Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
