Indesit IDF125. Start/Stop light flashing, machine has stopped
My Indesit ICF 125 dishwasher has developed a fault which is not referenced in the manual supplied. There has been a grinding noise for the last few weeks from the lower part of the machine and now about 10 minutes into cycle the machine has stopped and the Start/Stop light is flashing rapidly. A further problem is that the detergent dispenser no longer opens during the cycle. What is the likely cause of these problems????
  • 105 Answers
SOURCE: indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
SOURCE: Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Posted on Mar 31, 2009
Water is not heating up
It could be heater element fault. Thermostat fault. Lastly check circuit, not switching the heater function.
Sep 30, 2010 | Indesit 24 in. D63 Free-standing...
Jvc sxpw650, my house was hit by lightening and now my sub makes a loud noise and the receiver which was grounded reads overload after the speakers work for a few seconds! please help? can i just replace...
The reason it goes into overload is due to the fact that the power amp section parts have developed a short and thus causing an overload in the power supply. The affected parts need replacing and I rather suspect that the subwoofer amp section has also developed a fault. I rather think with the lighting damage that you might have to replace the lot! And not just the subwoofer!! If your house was insured replacements might be covered by that. If not you sound like your in for a big bill!
Jun 22, 2010 | Audio Players & Recorders
Indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
May 05, 2010 | Dishwashers
Indesit idf 125 dishwasher
you don't need salt in the dish washer?
Feb 11, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Feb 28, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit dishwasher
Feb 23, 2008 | Dishwashers
Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Dec 30, 2007 | Indesit W 123 Front Load Washer
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
