Question about Hotpoint Washing Machines
Why is our Hotpoint WDL520 washer-dryer tripping the RCD when drying?
We've had the above model of washer-dryer for approximately 3 years now without a problem. Recently though, it has begun to trip the RCD during the drying cycle. It will wash with no problem, then when we put it on to dry it will trip about 10 minutes in. Once back on though, it dries without a problem. I've only done this a couple of times to try to determine whether it was an ongoing problem, and the same things happen. Tried different sockets, no change. Any suggestions would be welcome, thanks.
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
SOURCE: Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Posted on Dec 22, 2008
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Posted on Jan 19, 2010
I need to a manual for hotpoint aquarius WDL520 washer dryer
you can download the instruction manual from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Hello I have a Hotpoint WDL520 washer/dryer and do not know how to use the dryer. Can you please instruct me what I can push to put the dryer on? Thank you Sian
Methinks you need a manual- for now and probably later ;-0) You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 19, 2011 | Washing Machines
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wdl520 washer dryer is no longer drying my clothes. I still spins but there is no heat for the clothes to dry. Is there a reset button on this model or is it going to be more serious??
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 28, 2010 | Hotpoint Washing Machines
Dryer tripping RCD
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Washer/drier tripping rcd!
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
Nov 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
109 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
