Dyson soap dispenser drawer wont stay closed during wash cycle
  • 1462 Answers
SOURCE: Sticking dispenser drawer
no other way then force but having got it out you should try to estabish why it is sticking
Posted on Apr 01, 2007
SOURCE: Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Posted on Jan 18, 2008
SOURCE: Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Posted on Apr 05, 2008
dutchman05
  • 487 Answers
SOURCE: soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
  • Part for Model# WM2277HW
  • Part# 5221ER1003A
( ) indicates recommended quantity Valve assy, inlet
Posted on Apr 17, 2008
SOURCE: Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
Posted on May 17, 2009
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
Tip
Dishwasher does not dispense cleaning tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
The soap drawer on my dyson washing machine wont close properly
my cr01 memory did suffer from this problem
i found the hot water entering the machine was too hot and the outer part of the soap dispenser had become distorted.
the solution is a replacement outer part.
bear in mind Dyson will be no longer supplying parts or support for the washing machine at the end of this year
Sep 19, 2012 | Dyson Flowcheck CRO1 Front Load Washer
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Dispenser drawer opening on WAH6700AWW
try take the drawer out and clean the inside where the drawer fits into. It may have a build up of soap/softener etc.. then give the drawer itself a good clean including the bottom of the drawer. I have this problem from time to time where there is a build up of soap etc...
Oct 25, 2008 | Maytag Neptune MAH6700A Front Load Washer
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
