Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Location of seond memory slot
Can you tell me the location of seond memory slot on s series notebook. I have 2 512 MB of memory and I can only find one slot my card supplies tell me there is a sonond slot but no idea where it is
    Novelist:
  • 126 Answers
Yes there are two slots of memory in ur computer and all u need to do is that follow the link below and u will be able to understand it clear;y
http://www.upgradecomputermemory.com/installguide.cfm
hope it will help
Posted on Jan 26, 2009
I have an Acer TravelMate 514T PC Notebook running with only 64MB RAM, and I want to put in a 256 MB RAM. How do I make the notebook recognize the 256 MB RAM card?
Mostly what I came across this models they only can detect until 128 mb and they do run a little faster than having 64 mb.And see if the card is pc100. and it is also dependent on what is your operating system is.If your notebook memory slot is two get two 128mb and you'll have 256mb.
Oct 31, 2010 | Acer TravelMate 514T Notebook
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Cheers.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
Sony Vaio Notebook, PCGK74/PCG9R3P hardaware issues.
Not sure, dude..Probably you better ask Worldvet or Ekse, who are better at these things..
You dont have to rate this, as i didnt really provide a solution. But good luck!
May 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
Acer Aspire 5610-4648
Good Day,
You are on the right page, the video memory(VRAM) is located directly on the video card, which means you have to replace the whole card. The good news is they are pretty easy to install. Make sure you check the spec of your card and get the right socket, AGP or PCI. When you look at the slot on your motherboard if the video card is plugged onto a brown slot it is AGP, if it is a white slot it is PCI.
Hope this help.
Mar 11, 2008 | Acer Aspire 5610-4648 Notebook
RAM replacement of Compaq Presario V2000
you'll need to go to www.hp.com and ask that question in the accessories area...
Mar 08, 2008 | HP Compaq Presario V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
202 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
