Question about GE Dishwashers
How do you clean out a filter on a GE Pot Scrubber Dishwasher GSD1380
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
SOURCE: General Electric Pot scrubber Dishwasher
My potscrubber 650 does not drain each time after use, what can I do to fix this?
Posted on Sep 16, 2008
chazman05
  • 48 Answers
SOURCE: Dishwasher leaving residue inside unit after wash is complete.
THere is a no filter on this unit just a strainer which is visible when opening the door.(its located near back on the bottom) You can take it off and check for pieces of trash or things that have made it by. The best idea is to take a few cups of vinegar (white) and put it in the soap dispensing door. Also take a big Glass and leave it upright and fill it with vinegar. Then run a normal load but dont use any other soap. ALso if your unit has a spot use Jet Dry or simliar products they really do help.
Goodluck
Posted on Dec 11, 2008
  • 464 Answers
SOURCE: My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Posted on Oct 15, 2009
tattootech2
  • 72 Answers
SOURCE: Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Posted on Apr 08, 2010
Top rack of kitchenaid dishwasher not getting clean.
We all know and I am sure you do to that manufacturers make great boasts about their products. They make great commercials. But the only real pot scrubber is you or I. They only sanitize so getting them scraped out not washed is a good idea before loading up. The hot water which is what it runs off of with the booster is what really performs the real work.
Apr 07, 2013 | KitchenAid Dishwashers
I have a ge pot scrubber quiet power 1 and I need to replace the sprayer arm-don't have the model number-can you help?
Hello, afossett
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Aug 24, 2011 | Maytag Dishwasher
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Goodluck
Dec 11, 2008 | GE Dishwashers
Dishwashers Logo
171 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
