Question about Dymo LabelWriter 330 Thermal Printer
Starts printing black lines in a short space
When I start the print job it seems to work, however it only prints a concentrated section of black lines. The paper feed function works fine. It will feed right up to the next segment as it is supposed to, however when printing it does not work properly.
Please help, thanks, Tim
    Genius:
  • 2,120 Answers
You have a bad thermal head. Uneconomical to repair. Sorry
Posted on Jan 27, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
How to fix the problem on the canon ir3225 that display NG #853 in the result section after commanding from pc.Even after installing ufr driver still is not working.
#853
Cause
-Using the wrong printer driver.
-The machine does not have the proper printer kit installed (e.g.
UFR, PCL, PS kit(s)).
-The print job did not print because due to lack of
resources on the printer (e.g. memory, HD space, etc).
-Print spooler on the machine is full.
-The number of secure print jobs have exceeded the
maximum limit that can be reserved at this time.
Remedy
-Make sure that the printer driver that you're using is the correct
one for the operating system on the computer that you are
printing from and specific to the printer model that you're printing
to.
-Check and verify that the correct and the required printer kit is
Installed (e.g. UFR, PCL, PS kit(s)).
-Reduce the number of pages to print.
-Erase unnecessary jobs that are stuck or in reserve.
-Turn off spooler on the printer, ADDITIONAL FUNCTION >
SYSTEM SETTINGS > NETWORK SETTINGS > USER
SPOOLER, set this value to OFF.
-Print out or erase secured print jobs that are stored or waiting to
be printed on the machine.
May 27, 2014 | Canon imageRUNNER 3225 Black and White...
I am having a black line go through any document or picture i print
o into the Printers Properties section and force a cleaning cycle and then print a nozzle test print. This will tell you a lot more about your printer and what is working and what is not. If you want more information just click Here.. Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
Apr 04, 2014 | Canon PIXMA MX310 All-In-One Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Use on black cartridge
When you start to print out a job or document, the job starts with the print box. Your default printer will appear in the drop-down box. To the right of that box is the properties box, open it with a click. The top tab marked COLOR is selected and you want to select the block, "print in grey scale only". When you start to print another job, the greyscale will have to be set again and again. Some printers will let you remove the color Cartridge and print only in B&W, but not many. (some HP's)
Apr 05, 2010 | Dell 924 All-in-One InkJet Printer
HP PSC 2350 all in one printer Is not feeding properly and message reads paper jam. Paper feeds almost until it should have finished the job, but no printing at all has been done. It started making a...
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Oct 15, 2009 | Computers & Internet
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
My lp2844 keeps printing part of the job on one label and the rest on the next. It seems like it starts the print job in the middle of the label and prints across ther perforation and onto the next label,...
sounds like you have the printer driver set to the wrong paper size
unfortunately some of these drivers disregard the settings you do in windows and so you need to set it twice , once in the windows printer dialog and second in the configuration wizard of the driver
hth hannes
Aug 29, 2009 | Zebra LP 2844 Thermal Printer
Dymo LabelWriter 330 Thermal Printer Logo
273 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
