The charging stand does not stay down
SOURCE: Top housing for the charging stand for a Braun Syncro 7680 Electric Shaver
I just experienced the same problem and came up with this solution. Use a spring clamp to keep the top of the charging stand in place. It works like a charm.
SOURCE: Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
SOURCE: hi, My braun bs 5301 does
Check to make sure that the shaver and the charger are clean. It is not locking in because there is something that is not letting it go down in far enough. You can clean it with canned air.
SOURCE: Braun clean and renew charging stand cycles but
Sounds like pump is bad. The cleaning and charging unit will need replaced. You will find a replacement for 360 Complete models at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Testimonial: "Thank you for taking the time to respond, I appreciate the link where I can look for a replacement as well."
SOURCE: Braun 8995 clean and charge stand
it sounds like it may be dead, i do know of this great site that sells Braun stuff check it out maybe it can help. http://stores.ilikenew.com/-strse-Braun/Categories.bok
