Frigidaire(ATF6700FS1) front load washer reads Error 21 it will not drain.
The machine will not spin it reads error 21 what could be the solution to the problem any suggestions.
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
Posted on Feb 08, 2008
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
  • 34 Answers
SOURCE: washer won't drain or spin, get F2 error
Hello hernandez160,
The "F2" error is referring to excessive drain time. Unplug machine before working on it. Remove screws on bottom of lower panel and remove panel. The drain pump is behind the panel, It has a large round door on it, turn counter clock wise by hand to access pump clean out. Have lots of towels ready. Remove anything from pump (usually kids socks or small clothing articles). If nothing in pump clean out remove suction boot from drain pump and check there. If nothing there blow through the drain hose from the pump side to check if anything is stuck in the hose. If that's clear check the electrical connection on the pump, make sure nothing is loose or broken at the connection. If all this checks out good and it still wont work you probably have a bad pump and it will need to be replaced. If you do find something was blocked or clogged due to small clothing articles I would recommend a garment/lingerie bag to keep all the small stuff together during the wash cycle. Hope this helps to fix your problem. Please remember to rate this and every solution you get.
Thanks,
edgin96
Posted on May 20, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Washed some rugs with rubber backing that tore up during the final spin cycle and now the water will not drain or spin
Clean the filter in the accordion hose just before the pump. It is clogged and or materials have reached the pump. You will get an error E 21
PanamaGuy
May 14, 2011 | Frigidaire GLTF2940F Front Load Washer
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Affinity E21 error
Nov 19, 2007 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
