Question about Drills
Titan Drill Charger not working
Hi All. The Battery charger for my Titan CD128G Drill has stopped working. I have tried to get a new charger, But on one sells them. The Number on the charger is TTB307CHR. Please does any one know or any other charger that will work, The battery slides into the Charger with a click. When i insert the battery into the charger, the red light comes on, But it has a very loud clicking noise, And the battery will not charge. Many Thanks Dave Gould..
  • 384 Answers
SOURCE: 14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Posted on Jun 26, 2009
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
  • 3 Answers
SOURCE: ryobi battery charger
The same thing happend to my charger, i let it cool down and now the green light goes off and shows red again. thanx for that post
Posted on Mar 22, 2009
radar001
  • 1051 Answers
SOURCE: My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Posted on Feb 21, 2010
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
How to tell iff batteries are uselss or need replacing or charger or drill itself
The first thing to do is get your volt meter and check if there is any voltage coming from the battery and compare that to what it is stopped to be. If the voltage is ok, install the battery in the drill and try to run it. If it won't run, you've got a bad drill. Next install the battery in the charger and plug the charger into your wall outlet. There should be an LED which flashes to indicate that it is charging. If you can get a full charge on the battery (verify this with your volt meter), try it in the dill again. If the drill will not rotate, there is definitely a problem with the drill.
Oct 05, 2015 | Drills
My product wasn't listed ... My Ryobi 7.2v drill stopped working (8 yrs old). I bought a new battery, not including the charger cable, and it charges just a tiny bit. Should I replace the cable or buy a...
After 8 years its possible you have some corrosion or bad contact on drill, takeing it apart an checking inside may be to much for you,but make sure all contact are clean on outside.
Dec 18, 2010 | Ryobi Multi-Volt Battery Charger
The charger simply stopped working. I don't want to buy a whole new drill. Where do I get another battery and charger? s.g.
Check with Ace Hardware, they will direct you to the manufactere for a replacement charger or perhaps a place that sells aftermarket chargers...sometimes you pay more for a charger then you would for the whole drill assembly, especially if they run it on sale.
Jul 02, 2010 | Ace Hardware PowerGlide 18V Trigger...
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Battery charger burn out.
If you have one of those little testers that has red and black wires with prongs on you can test by touching the metal areas on your battery. The red is positive and black the ground.
Nov 21, 2009 | Craftsman Drills
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Nov 15, 2009 | Dewalt 18 Volt Compact Drill Kit
Have a Fire Storm place battery in charger green light comes meaning full charge but place in drill there is no charge. Is it a new battery, or new charger, or new drill required
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Oct 16, 2009 | Black & Decker 18 Volt Cordless Drill...
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Drills Logo
144 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
