Question about Roper Washing Machines
Model RTW4440XQ0 WATER IN RINSE CYCLE ONLY FILLS TO THE LOW LEVEL EVEN ON HIGH AND MED LEVEL
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
Maytag317
  • 1136 Answers
SOURCE: water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
Posted on May 28, 2009
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
Mar 14, 2012 | Washing Machines
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
I have a Roper washing machine (Model: RTW4440XQ0, Serial #: C11740048) that is less than a year old. When you start the machine on any cycle (on high water level) it will fill up with water and run...
The machine was built to adhere to the low water guidelines of your overly intrusive government. Bought a new machine with the same problem. 1/2 tub of wash water and 3"-5" of rinse water. 3 different local service shops and the Whirlpool people said neither was adjustable. I found this unacceptable and decided I was going to make it work the way I wanted not the way the government schlocks said I must. Took out the 2 screws on either end of the control panel ( where all the controls are) lifted it up and found 2 ADJUSTABLE water level control switches. One 3-way for the wash water and one for rinse water. Cranked them both in and now I have a full tub of wash water and the same for rinse, Vote in 2012 to keep the government out of our homes and our lives,
Sep 14, 2011 | Washing Machines
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
Aug 23, 2011 | Estate ETW4400VQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Agitator starts before water fills. When adjusting
There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Apr 20, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
