Question about Sony Handycam CCD-TRV608 Camcorder
Pinch Roller Does this just press back on?
  • davee2448 Jan 26, 2009
    This pinch roller was for the Sony CCD-TRV608.
  • 10,594 Answers
There is a small plastic roller that holds pinch roller as shown in below image...
Posted on Jan 26, 2009
  • Shahid Electronics
    Shahid Electronics Jan 26, 2009
    As per Sony part policy, you should buy complete pinch roller assembly and replace it.
Ad-f410 change pinch roller
Why do you want to change the Pinch Roller? Most of the time they just need a good cleaning and other things in the deck like back tension checked. Pinch Rollers are only changed if they are cracked and I have seen few cracked Pinch Roller in 40 years.
May 02, 2014 | Audio Players & Recorders
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
I have a Sony TC 630 Reel to Reel Stereo Tapecorder..Pinch Wheel is sticking and will only move when forced and brushes as well...Any help ?
Sounds to me like your Sony has a common problem among vintage reel tape decks..dried /frozen grease/ and or a lack of lubrication. carefully apply a tiny bit of fine lube oil, like 3in1, on the swing mechanism that carries the pinch roller...(you may have to remove the front metal deck face to fully access the swinging pinch roller mechanism) ) . do NOT get any oil on the rubber pinch roller..(best to make sure after by scrubbing the pinch roller surface with a cotton swab lightly dipped in non chemical household cleaner, like 409, or awesome orange i get at the dollar store. Then use the dry end of the swab to ensure the pinch roller is dry. .The pressure pads should swing upward and press the tape against the heads when in play/record mode..if they do not swing up, they are binding/ or out of adjustment....they are spring loaded so when the reel deck is in the stop position the spring loaded pressure pads are held down...play/record mode releases them to freely swing up and press on the tape against the heads.
May 11, 2010 | Audio Players & Recorders
Playback Sony Professional Walkman
Sounds like the pinch roller isn't engaging. The pinch roller is a black rubber wheel that presses against a silver post (capstan) the tape is held between them. With the door open and no tape press play. The roller and capstan should touch. If it recently ate a tape there could be some tape on the capstan that also will cause it to run fast.
Feb 03, 2010 | Sony Audio Players & Recorders
R360 wont feed paper in to printer
You need to clean the pinch roller at the back of the printer using a cleaning sheet. These come with packs of Epson Photo Paper and are slightly tacky which removes the paper dust and grime from the pinch roller.
Mar 12, 2009 | Epson Office Equipment & Supplies
Part ID
# 763 is different thing, a roller fixed under pinch lever pin for smooth run.
# 760 is complete pinch roller assembly including snaps on top of pinch roller.
Feb 03, 2009 | Sony Handycam CCD-TRV608 Camcorder
CCD-TRV608
You are missing pinch roller lock, its like piece of plastic tube 2 or 3mm (1/8 inch)
This part is not available individually as you need to purchase complete "pinch roller assy" and fixing it requires skills and experience of camera repair.
Jan 30, 2009 | Sony Handycam CCD-TRV608 Camcorder
Error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Apr 13, 2008 | Sony Betacam SP Small Videocassette 30...
DCR-TRV20 Problem when reproducing the video.
THESE HAVE A COMON PROBLEM WITH THE PINCH ROLLER RETAINER. THEY CRACK AND WORK THEIR WAY UP AWAY FROM THE PINCH ROLLER AND SOMETIMES FALL OUT COMPLETELY. IF YOU CAN FIND IT ,THEY CAN BE TRIMMED AND REINSTALLED. LARRY
Jan 17, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Noisy capstan which runs continously
most tape decks are designed so that the spindle will run when powered on. when you press play or record, the pinch roller elevates the tape to the spindle, tape starts to travel.
noise is basically from the mechanism, or deteriorated in time as yours is an used one. if you are lucky to find some good pinch roller rubbers of same diameter, replace them.
pc-cook
Jan 15, 2008 | Audio Players & Recorders
Sony Handycam CCD-TRV608 Camcorder Logo
266 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
