Question about Keurig B60 Coffee Maker
Coffee stops brewing
Is in brewing cicle but my coffe doesn't came out
  • 1,511 Answers
Plugged Needle. Clean with Pin. See Manual
Posted on Jan 31, 2014
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
heatman101
  • 43501 Answers
SOURCE: won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: coffee brews but doesn't fill cup, already
heatman101
heatman101
  • 43501 Answers
SOURCE: Won't pump. Says it
heatman101
Posted on Sep 03, 2011
heatman101
  • 43501 Answers
SOURCE: when I brew a cup
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 05, 2011
Ours does not finish cycle either!!! The machine runs through the cycle up until the point where water should enter the "brew group". The coffee doesn't come out. What shall we try?
I just fix that problem by opening the water flow meter by some coffee grinds, also had a little coffe grind jamming a check valve that is at last of the water pump flow, now is running pretty well
Dec 20, 2012 | Saeco Easy Espresso Machine
My keurig coffe maker says it id "brewing" but
heatman101
Aug 09, 2011 | Keurig B100 Coffee Maker
Won"t brew the coffe right and hot water coming
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
When I brew a cup of coffe, the brew message on there takes forever to stop saying it, even after it has stopped brewing
heatman101
May 04, 2011 | Keurig B70 Coffee Maker
The coffe pot will not produce full pot of coffee it only produces 1/3 then stops i cked water supply that is fine when restart it will only produce another small portion so it is three or four times for...
Check programming.This is very simple;turn switch on and hold brew switch until you here 3 clicks to start brew timer .When desired level is reached turn off on/off switch on front panel to set brew time.Check brew level now.
Jan 24, 2011 | Bunn CDBCF 15 APS Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
Keurig B60 Coffee Maker Logo
18 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
