Question about Frigidaire Refrigerators
Frididare model LFBC46F5LS doesn't run.
Doesn't run
  • 3567 Answers
SOURCE: 2000 650 v star.
So check the compression. The valves could be set wrong or are not sealing well. You didn't mention any smoking so the piston rings should be okay. The most likely cause of the problem is a pin hole in the carb diaphragm or a carb needing to be cleaned. Go ahead and drain the float bowl then remove it. Now clean the carb with spray carb cleaner. With a bit of luck the cleaning alone will fix the problem. Please rate my answer. Thanks.
Posted on May 10, 2011
  • 4736 Answers
SOURCE: compressor seems to be overheating
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
Posted on May 22, 2011
heatman101
  • 43501 Answers
SOURCE: My Goldstar Dehumidifier model DH404ey7
Hi, Yes. I would say that your compressor is dead...
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
  • 21 Answers
SOURCE: The dvd driver doesn't work.
Did you check your DVD player program setting?
What about DVD region setting for? (If you use non-us DVD like PAL.)
Posted on May 28, 2011
  • 157 Answers
SOURCE: icemaker doesn't work....It doesn't fill
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Posted on Jun 22, 2011
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Why doesn't Ewave refrigerator model EWR121W doesn't get cold?
The cold control (thermostat) may be defective
Apr 10, 2013 | Refrigerators
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
The hard drive don't running
Check connections. If that doesn't work, try putting it in a different computer. If that doesn't work it's probably broken.
Feb 11, 2012 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Flash_integration.min.js i get this message everytime i load empireand allies game on zynga
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.2; EasyBits GO v1.0)
Timestamp: Sun, 18 Dec 2011 09:17:33 UTC
Message: Object doesn't support this property or method
Line: 1
Char: 209
Code: 0
URI: http://assets.castle.zgncdn.com/19555/js/flash_integration.min.js
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Sep 30, 2011 | Microsoft Internet Explorer 8
Washer won't agitate or spin
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
Refrigerators Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
