Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
How to clean out a hot spot steamer? clogged - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
    Genius:
  • 1,669 Answers
Go to the hardware store near you and get steam iron cleaner and follow the instructions on the package.
Posted on Jan 20, 2013
Steam xpress homewell
Marg:
If you have been using tap water, your steamer is probably clogged with calcium or lime. I would pour some CLR (Calcium, Lime and Rust remover) into it and let it sit for a few hours. CLR can be bought at Home Depot or Lowe's.
Jul 03, 2014 | Vacuums
My steamer gets hot but no steam if very little is coming out what do i do
clean it with lime away where the steam comes out it has had hard water build up that has clogged your openings
Apr 06, 2012 | Euro-Flex Monster 1200 Handheld Steam...
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Proheat clear view
check to see if the spray tips are clogged with soap. when you remove the water tank you will find them located on each corner in the front of your steamer. they are usually red in color. pull both side tabs together then lift out. remove clamp then carefully pull the hose off. i have had the hose rip on me before so do use caution. you should see the clog if there is one and should come out in hot tap water. there are several things that could cause this problem but this is the most likely. good luck!!!
Sep 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
55 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
