Question about Garden
Pressurewasher runs fine then shuts down and cant pull
I had my carb rebuilt at a local shop. It ran fine for about 2hours then it sounded like motor started to struggle and then stalled. I tried to pull start it and couldnt with both hands. I thought great now its seized.. A few hours went buy and it started up 1st pull and ran fine for about 5 min then struggled again and couldnt pull till cooled down. Please help new home has filthy pool deck and driveway.
    New Friend:
  • 3 Answers
Same thing happened to me and I found out that water was getting into the carb filter media. Try taking the carb filter cover off and see if the foam filter is wet. If so, try starting without the filter and see if it works. THis issue used to drive me crazy on my unit, hope this helps.
Posted on Jan 20, 2013
2 Suggested Answers
faretsrq11
  • 13 Answers
SOURCE: press washer starts an runs
The previous solutions are very important to confirm first. If your pump is in good serviced order then look to a valve adjustment.
Posted on Oct 20, 2012
Is there a quick fix, easy fix if no, tell me the right way.
it sounds like there maybe jets within the carbs that maybe blocked.
Im not familiar with the carbs you mentioned but they all work in a similar way. The jets are small tubes that screw into the body of the carbs (internally) and have small pin holes in them similar to a sieve that let the fuel pass through, the tiniest speck of debris from the tank or fuel lines can block these.
Is the bike fuel injected? if so it could be the injectors, they also have a very fine mesh over the end where its inserted into the cylinder head, these could be faulty or possibly blocked.
Hope its of help
tony
Jan 22, 2016 | Yamaha 97-98 Mountain Max Vmax Sx Sxs Xt...
My tomahawk 110 atv will not start. I have rebuilt carb , replaced spark plug and it cranked and ran fine until I opened it full throttle and then it started sputtering and diedand now Iit will not re
You need three things to make any gas engine run, in this order double check make sure you have proper timing set, spark and fuel. Could be bad gas or a bad ground from motor to frame.
Dec 02, 2014 | ATVs
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
93yz250,got the motor rebuilt,and it ran good 4 about a week,it reeved up on it's own i shut it down now the pain in the ... wont start bk up . it's got spark,comp good ,carb seems 2 b good,theres...
I doubt the repair shop has done anything wrong. Yes, it sounds like an air leak between the carb and the head. Try tightening the mounting screws and bolts. Also check the tightness of carb screws on the choke etc.. Now check tightness on the head bolts and other mounting hardware on the head. Be sure the throttle is operating properly and the cable is not kinked or pinched.
Aug 19, 2011 | 2004 Yamaha YZ 250 F
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
Gas flow continuing when tiller is off
Yeah it sounds like the guy messed up up on the float level, an easy mistake, I would take it back to them. It isn't dangerous, maybe a few blisters, the fuel shut off is fine for long term, but not 5 mins. The white smoke is as you said, unburnt gas. I had a 57 ford tractor that I couldn't get the floats set on no matter what, when it was running, it was fine, but shut it off and you come back to an empty tank! I just put the shut off in the fuel line, problem solved. Hope this helps.
Apr 24, 2010 | Troy-Bilt Chipper Shredder
My question is this I have a 1983 toyota pickup truck with the 22R engine.About a week ago I pulled out ot my drive way and when the motor warm up it started to run rough and black soot was coming from my...
black soot is a running rich condition it's getting to much gas not enough air .. 14-1 ratio air to gas your carb rebuild needs to be rechecked for sticking float..
Nov 19, 2009 | 1983 Toyota Pickup
Lawn mower motor
No it's sounds like the float in carb is stuck I've had 3 motors do this I put a fuel shut off in the line after I cleaned the carb out and rebuilt it. The problem is the gas breaking down an gumming up the float in carb. Drain the oil and an run some oil thur it to get the old gas out make sure you clean the carb out to.
Sep 20, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
