Question about Asko W6761 Front Load Washer
Where is the fuse on a asko w6761 washer - Asko W6761 Front Load Washer
5 Suggested Answers
  • 351 Answers
SOURCE: asko w6761 front loader
you can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Posted on Mar 02, 2008
  • 351 Answers
SOURCE: Asko W6761 washing machine frozen
it looks like the control board needs replacing the part no is on the board and starts 80,but first can you get into the menu option or has it locked you out
Posted on Aug 28, 2008
  • 299 Answers
SOURCE: how much is a 7 year old asko w6761 and t761 worth
The value of a 7 year old washer will vary with it's condition and how much it's been used which isn't stated. For example, a washer kept outside or in the garage and used for a large family on an almost daily basis is going to be worth a lot less than a pristine looking unit that has been indoors and used do to a couple of loads a week. Same as you'd judge the value of a used car. Assuming the unit is in excellent condition and works perfectly, a used machine may sell for up to $250. Beyond that most people will opt for a lower end new machine with a warranty rather than a more sophisticated older one that will most likely soon need repairs. Idea: Consider donating it to a women's or children's shelter, halfway house or homeless shelter. You can usually value the contribution at half the retail cost and deduct it from your income if you itemize. The tax savings may be worth more than what you'd get selling it. Just be sure to get a letter from the charity to substantiate the deduction.
Posted on May 02, 2010
ericallen26
  • 660 Answers
SOURCE: what size fuse does asko washing machine take
no size given, but here is the part.
http://www.repairclinic.com/PartDetail/Line-Fuse-and-Holder/8801354/1460992?modelNumber=W6761%2FStainlessSteel
Posted on Dec 06, 2012
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
Wash motor fault
If so you an check if the motor is working separately out of the circuit. If so there is fault on the control drive circuit and so the output to the motor drive could be a suspect.
Feb 28, 2013 | Asko W6761 Stainless Steel Front Load...
What size fuse does asko washing machine take
Dec 06, 2012 | Asko Washing Machines
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
1. Power it on
6. Power it off and on, again
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Asko w6761 front loader
Oct 10, 2007 | Asko W6761 Front Load Washer
Asko W6761 Front Load Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
