Question about Craftsman Saws
Craftsman 10" table saw losing power
Was cutting 1/2" plywood today on a saw that doesn't get used much. Saw lost power, started to sell a bit, I can see sparking in the motor (arcing?). Any idea what's going on?
  • chrisdesaute Jan 29, 2009
    Thanks for the feedback. The model is a 113.221740, craftsman 10", I'm estimating 10 yrs old or more. Was given to me by a friend, he used a lot, I use very infrequently, but plan to do more now that I have my shop set up.
    I had been cutting 1/2" and 3/4" plywood with no problem. Then while cutting a 1/2" piece (all pieces were roughly 18" square), I noticed a loss of power, and after a while a (presumably) electrical smell. I noticed the arcing, which as you say, maybe has always been there (I never looked before). I blew out the motor with compressed air, checked the blade by hand (seemed to rotate freely). No obvious problems, ran no better after blowing out the motor.
    The blade is old, I likely need to replace. When I say it's not usedt often I mean this thing sat for months, then I made about 10 cuts on it over the course of two days.
    I fired it up again the other day, and everything seemed ok again, I did not cut anything. I have not yet pulled the motor. thx!
  • bchadra May 11, 2010
    How old/sharp is the blade? How often is this saw used? What type of motor is on the saw?
  • 2,176 Answers
Depending on how much "arcing" you see it could be a couple different items. First some arcing is normal and usually runs across the brush edge, but if it is a lot and goes around the armature then it could be a brush spring that collapsed or worse the armature has an open or damaged segment on the commutator, I would take the brushes out first and look at them (unplug tool first) the edge that rides on the comm should both look the same and the spring also. If you can see then turn the blade by hand and look at the comm thru the brush tube for a different looking bar on it. Let me know the model number and I will pull up a breakdown and see if I can help you further.
Posted on Jan 27, 2009
I was given a 10" Craftsman table saw, which has a lot of surface rust on the table. I have been told by friends to use a fine grit sandpaper, other said Navel Jelly. What is the best way to remove and...
You can use scothbrite or something synthetic scrubbing pad with mineral spirits/ oil . Once the rust is removed, try to apply paste waxes so that the rust will not return. Always clean your table saw. This worked on my band saw.
Sep 12, 2013 | Craftsman Saws
New blades, new belt.. burning the wood when I try to maky any type of cut
Is the blade the correct one for the type of wood you are cutting?? There will be recommendations on the saw blade. Finer toothed blades are for plywood, etc. Aggressive or large tooth blades are for thicker wood.
May 15, 2012 | Craftsman 10" Table Saw
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
Cutting 3/4 plywood with craftsan table saw. Motor stopped ???
either overheated the motor and there is a reset at the back--it's a button make sure your out of your wood and fingers away from blade, push it in, see if it restarts, could be a bad extension cord ,connection at the plug ins or you blew a fuse. 3/4 kinda tough
also blade might be dull.heated motor and shut it down.
Oct 31, 2010 | Craftsman 10" Table Saw
While cutting a piece of scrap plywood on my Craftsman 10" table saw, I accidentally cut through a bolt and it caused my saw to shut off. I pushed the reset button several times, but it doesn't feel as...
First off the saw will have to cool down and then the reset button will take some major force to reset. You should hear a distinct click when it does...
Sep 20, 2010 | Craftsman 10" Table Saw
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
Just purchased a used craftsman 12'' commercial table saw model # 113.29930 just looking for a service manual
I have a paper manual for a 113.29970 12" direct drive, probably the same basic saw. I sell craftsman table saw parts on ebay as "hokienpokie" or you can contact me via email too, Jim
Feb 05, 2010 | Craftsman 10" Table Saw
Need dado throat insert for 113
why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Dec 11, 2009 | Hardware & Accessories
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Saws Logo
349 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
