Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore model #79577543600 freezer cold but frige is not cold
  • 90 Answers
SOURCE: freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Posted on Jan 05, 2008
tzweeb
  • 318 Answers
SOURCE: frige and freezer not getting cold fan is working
there is a problem with the compressor realy. it is mounted to the side of the compressor and when the coils get plugged with lint they will overheat and short out.
clean the coils and remove the relay, a white box looking device and shake it in you hand, if it rattles or has pieces coming out of it, then it is bad and should be replaced.
Posted on Dec 28, 2008
  • 9 Answers
SOURCE: leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Posted on Mar 14, 2009
tomsat69
  • 214 Answers
SOURCE: fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
Posted on May 10, 2009
  • 103 Answers
SOURCE: frige not cold,freezer working ok
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. Look at the heater. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
Posted on May 31, 2009
79577543600 LCD not working
You can find the part you need by putting that model number into the sears direct parts website
Mar 01, 2014 | Kenmore Refrigerators
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Does not get cold for freezer or main frige
IT MAY BE BLOCKED UP WITH FROST, TRY REMOVING FOOD AND UNPLUGGING FOR AT LEAST 6 HRS WITH DOORS OPEN.
Jan 13, 2010 | Kenmore 57029 Side by Side Refrigerator
We have just purchased a second hand, one year old, stainless steel fridge and freezer. The freezer is just not cold enough. We have it set on maximum, but the best it does is keep water cold. It did not...
can you hear the fan running in the freezer. is the fan under the frige running, is it clean under it, is the the back cover missing where the compressor is. please provide a full model number for step by step help.
Jan 08, 2010 | Kenmore Refrigerators
Freezer works fine but frige side not getting cold enough-side by side unit
Check rear wall of freezer to see if you can feel frost about halfway down. If so you likely have a defrost system problem. Three components involved in defrost system, Heater, defrost thermostat and defrost timer or Defrost control (circuit board).
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Kenmore Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Fridge not cold, freezer fine...
look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Nov 25, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
27 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
