Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
Only get one tub of hot water from 50 gallon hot water heater
    Problem Solver:
  • 11 Answers
One of your elements probaly shot
Posted on Jan 20, 2013
  • 92 Answers
SOURCE: 6 yr old electric rheem fury 50 gallon all of a
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Posted on Mar 26, 2009
rick_stokes_
  • 61 Answers
SOURCE: No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Posted on Sep 19, 2009
Testimonial: "Thank you very much, Rick! "
  • 297 Answers
SOURCE: Rheem 50 gallon gas water heater less than one
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
Posted on Sep 29, 2009
  • 2926 Answers
SOURCE: I have a 41v50 gas 50 gallon hot water heater and
If it is leaking from the tank, you'll have to replace the heater.
Posted on Feb 17, 2010
  • 193 Answers
SOURCE: Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Posted on Apr 21, 2010
Testimonial: "It is very good advice. I bought a tester to check out both upper and lowre thermostat and heating element; I've replaced the lower heating element "
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Sep 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
44 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
