Question about Whirlpool GSC9455 Top Load Washer
Just spins during the wash cycle
My washing machine just spins in a slow circle when it's in the wash cycle. I am pretty sure that it is supposed to agitate (swish the clothes back and forth to get all the dirt out) It's doing the job as of right now - I just don't think it's washing the clothes to it's potential because it's not agitating. Can anyone explain to me what to do. It happened after I moved my washer from one apt to another. It's not even a year old. Please help. I don't want to pay for service.
  • Jayne Arthur Jul 17, 2007
    I will try that out and let you know... speedy response by the way. Thanks!
  • 274 Answers
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Posted on Jul 17, 2007
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Squeaking washing Machine during spin cycle
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Feb 01, 2010 | Kenmore Washing Machines
80 series does it agitate or go in a circle
it is suppose to agitate during wash cycle
May 26, 2009 | Kenmore Washing Machines
Agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Mar 12, 2009 | Whirlpool LSB6200KQ Top Load Washer
Need information about an old ASKO 10604 washing machine
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Jan 23, 2009 | Asko W6021 Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Won't hardly spin
the back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Jan 14, 2008 | Washing Machines
Whirlpool GSC9455 Top Load Washer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal De
