Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Need door latch and door gasket for 18" frigdaire dishwasher
The only numbers I found were on the inside right side of the dishwasher and they are MDR251RHRO and TH94144530 ,I am having a hard time locating these parts,hopefully you can help.
  • 130 Answers
I bet you can find them at appliancepartspro.com just use the model number (D/W) and then you are set.
Posted on Jan 26, 2009
Simpson Silencio 850 dishwasher,model No. 52B850SH A lot of times after a wash cycle has finished the dishwasher does not empty out all the water and leaks out water from somewhere onto the floor in front...
Hello.
Is there a puddle in front of your dishwasher? Often this is a relatively easy problem to solve. At best, all you need to do is tighten a few fittings or level the dishwasher so water doesn't slosh out when the machine is running. At worst, you may need to replace a door gasket.
Instructions
Tools Needed to solve the problem.
Worm-drive Hose Clamp,Adjustable Pliers,Adjustable Wrench, Replacement Door Gasket, Screwdriver,Small Level
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Thanks
Oct 30, 2011 | Dishwashers
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Step 2:
Step 3:
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
Step 3:
Step 4:
Step 5:
Apr 06, 2008 | Dishwashers
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Water leaking at the bottom of the door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
After dishwasher was in cycle, I returned to kitchen and found puddle of water on the floor in front of it, water leaked down to basement. Haven't used since. Tried starting a cycle, but afraid to allow...
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of over $100.
2. Replace the door seal at a cost of about $35-$40.
If you need parts, they can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is usually listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges.
If you have questions, or require additional assistance, please post back with a complete model number so that I may be able to provide you with better service. hope this helps you.
Nov 10, 2009 | KitchenAid 24 in. KUDP02FRSS Stainless...
I noticed water on the floor (right corner) and my concern is that I have hardwood floors. It is not a lot that I can see but my concern is that water is leaking underneath where I can't see. It is 8yrs...
Are you sure the water is coming from underneath the dishwasher? From the symptoms you described, this sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. Some other items that can contribute to leaking are:
1. Replace the inner door panel at a cost of about $130.
If the leak IS coming from underneath the dishwasher, you will need to remove the lower toe panel under the door and start the dishwasher to confirm wher eit may be coming from and at what point in the cycle it occurs (i.e., does it leak during the initial fill, during the wash cycle, or during the drain cycle). It will be much easier to determine a cause if you can narrow down the symptoms. Leaks under a dishwasher usually come from leaking hoses, or leaking grommets where the heating element is installed. In a worse case scenario, the tub could be cracked or have a hole melted through it (if plastic) from utensils that end up on the heating element during the drying cycle and heat up to melt the tub. You will need to do a thorough inspection and post back with the results, so that I may be able to advise you further if this is the case. If you need parts, they can be purchased from any of the following websites:
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
If the model number you have this listed under is correct, the part number for the door gasket is 902894. The part number for the inner door assembly is dependent upon your serial number.
I think I would pursue the cheaper option, first. Its also the much simpler option. Since your dishwasher is 8 years old, it is highly likely the door gasket is worn and needs to be replaced. To replace the door seal, follow these steps:
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. NOTE: I personally own a Maytag model such as yours and experienced the same problem. Replacing the door gasket solved the problem for me. It may for you, too. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 30, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Dishwasher door leak
    Hi
    Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
    Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
    If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
    A Fixya rating would be appreciated if you have found this solution Helpful.
    Thanks
    Rylee
    Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
    Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
    Step1
    Step
    Step
    Step
    Step
    5
    Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
    Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
    135 people viewed this question
    Top Frigidaire Dishwashers Experts
    Electrolux
    Electrolux
    Mike Cairns
    Mike Cairns
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
