Question about Whirlpool AWM8163 Front Load Washer
F H is displaying
Daily load setting started, then stopped with F and H displayed in the display
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Posted on Jan 20, 2013
  • Miv Elliot-Dunn Jan 20, 2013
    Thanks Richard will try what you say tomorrow. Sounds like you have the answer.
  • Richard Roth
    Richard Roth Jan 21, 2013
    OK, keep me posted!
SOURCE: Noisy when trying to spin. display uL instead of
If you can't get it to balance by redistributing the clothes, take some of the heavier clothes out and try again. 6600's sometimes have a problem with this. Mine does occassionally.
Posted on Jan 24, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a Whirlpool cabrio washer that displays LF
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 15, 2010
SOURCE: front load washer will not start
REPLACING BELLOWS
Posted on Jul 30, 2008
Jahn27
  • 1554 Answers
SOURCE: My Cabrio is just over
The problem is either the wash impeller is restricted or the basket is not getting fully disengaged during the fill. As the machine fills, the basket floats until the drive shaft and basket splined hubs disengage. The machine/motor controller operates the motor intermittently while the machine fills to detect whether the basket is disengaged by analyzing the current drawn by the motor. When the current drawn by the motor is more than what it should be when the basket is disengaged, the machine continues to fill until the basket disengages and the current drawn is nominal. The machine then overfills and flashes the fault code when the current drawn by the motor does not drop to its nominal value either due to the basket cannot disengage or the wash impeller is restricted.
Small garments can get caught under the wash impeller and restrict the impeller. It will cause the "oL" code to flash as if the machine is overloaded. Remove the wash impeller and inspect it.
Insert the blade of a small screwdriver into the slot in the impeller cap, then pry the cap up, and remove it.
Remove the 7/16? hex-head bolt holding the impeller to the drive shaft, then lift and remove the impeller from the basket. Lift the basket to remove the impeller easily.
Raise the washer top to the service position then take the basket out to inspect the drive system including the hubs if the wash impeller is not restricted. Dirt accumulation can wedge the hubs and prevent the basket to fully disengage. Clean the drive system including the hubs and it should resolve the problem.
Tape the washer lid closed then using a putty knife, press and unlock the two front top locks located approximately 6-1/2" from the outside edge of the washer and then raise the washer top. The basket can now be lifted put of the tub with the wash impeller removed and the washer top raised.
Posted on Sep 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet washer displays F-35 and stops
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) - 0 ohms
Pins 3 to 4 (Overflow) - 0 ohms
Pins 4 to 5 (L1) - 0 ohms
Pins 4 to 6 (Empty) - 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%$$##@@
Posted on Sep 30, 2010
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 | Watches
SERVICE MODE
From the manual I have
1. Press the power pad to turn on
    press home pad to ensure home screen is displayed
2. Press the help pad. the main help screen is displayed.
3. Press the help and start stop pads for 3 sec simultainiously.
    The factory test screen is displayed.
4. Press test load on the screen.
5. The contrast screen is displayed. Press the start/stop pad once to cycle through the screen
6. press start/stop pad. The test load screen is displayed.
More to come... I will try to copy and paste what it says. I can try to send a copy of the pdf if you give an email.
Oct 19, 2007 | GE WPGT9360EPL Top Load Washer
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
'out of range' on display after windows loads but
Boot in Safe Mode (press F8 while the pc starts) and set the screen resolution to a smaller value - it's in Control Panel, Display, Settings.
Aug 31, 2011 | Computers & Internet
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
How to turn off the ringer for HP 640 Fax Machine
Silent mode You can turn the sounds of the HP Fax (including ringing) on and off using the control panel button. You can also set all sounds to turn off on a daily schedule; for example, turn all the sounds off between 8 pm and 8 am. 1. Press Menu repeatedly until BASIC FAX appears and press OK. 2. Silent Mode will display. Press OK. 3. Select On-Daily and press OK. From: 00h To: 23h will display. 4. Enter a start time and an end time and press OK.
Jul 06, 2010 | HP 640 Inkjet Fax Machine
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool AWM8163 Front Load Washer Logo
230 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
