Asus p5pe no sound device
Device found named legacy on device manager
  • 3,606 Answers
Hello download the audio driver here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5PE-VM&os=&hashedid=k3h0ZFVu9Lo1dUvk
By selecting your windows system.
Open the audio folder, and click on global for download.
Please unzip the file before you install.
Reboot after the install is done.
Good luck
Posted on Jan 21, 2013
mrsno
  • 166 Answers
SOURCE: P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
Posted on Apr 19, 2008
syedmujahed
  • 158 Answers
SOURCE: NO sound on pc
you have the asus motherboard cd,
if you have then install the sound driver,
go to the bios setup and check there your sound is enable
reinstall the fresh copy of windows xp,
your motherboard warranty is finished,
give me detail of the motherboard
reply me i will help you
Posted on Sep 27, 2008
SOURCE: ethernet controller for asus p5pe vm
i have also a problem about ethernet controller, i can't access my internet connection !
Posted on Nov 02, 2008
  • 905 Answers
SOURCE: asus p5pe-vm sound driver need
this is where the audio drivers are
you will have to type in some letters at the bottom of the page(just under the red stop sign) , and then click the download button next to it
http://www.driverstock.com/ASUS-P5PE-VM-driver-download/6-9-10170-81101/index.html
Posted on Apr 01, 2009
  • 235 Answers
SOURCE: asus p5pe-vm audio driver 4 windows 7
the audio for asus p5pe is soundmax ad1888 as of now there no driver that supports win7 you'll just have to wait until the product manufacturer releases a driver that will support win7
Posted on Nov 21, 2009
Ther is no sound output device driver for win7 my asus m,b is (p5pe-vm) when i tried to install a driver using device manager nothing happened
Hello, the download site is here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
There is no drivers for windows 7.
But you can try the xp driver it sometimes work.
You just have to select the compatible mode
for win xp.
Select the windows version and select sound
Unzip the file before installation
Jul 08, 2011 | ASUS P5PE-VM Motherboard
My problem is my VGA card is not working on window 7 & for ASUS P5PE-VM. Can you give me a link for this VGA download or solutions
Ron, I found this posted somewhere:
Users running ASUS P5PE-VM on Windows 7 having difficulty looking for compatible drivers, especially on graphic card and onboard sound card. The graphic card is old NVIDIA GForce 3 TI (AGP) and the sound on-board is SoundMax which is listed as SoundMax Integrated Digital Audio (TCSUS_CH5) F5410AMR. The driver which comes with the motherboard will not install the sound drivers because it doesn't recognize the OS even though it listed the sound card but only Realtek and analog devices.Trying to resolve this problem using Compatibility mode doesn't do the trick as there is no Vista compatible for GF3 driver. Windows 7 apparently won't recognize GF2 series and older ones. You will have to upgrade the video card. Try using Windows Update. If it doesn't find the driver online, then it means the driver is not supported by Win7. No luck for NForce 3 motherboards either, or NF 1/2 motherboards. Another workaround you can try is by installing NVIDIA's legacy driver 66.93 which was reported doing good on GeForce 3 TI 200. You will have to disable all directX hardware acceleration, but OpenGL works. It looks like upgrading is the last resort you can try after you try all above solution.
I hope this helps & good luck!
Apr 01, 2011 | ASUS P5PE-VM Motherboard
I cant find a sound driver for asus p5pe-vm
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | ASUS P5PE-VM Motherboard
I have a asus motherboard p5pe-vm (865) . audio driver of motherboard are not work in windows7. please explain what i do.
did you try downlaoding the audio drives from ASUS website or try going to control panel then device manager then look for your sound drives then right click that driver and try to update the drivers there. If that doesnt work try uninstalling it then reinstall it hope this help you out
Nov 10, 2010 | ASUS P5PE-VM Motherboard
Sound my lettop dont have
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 03, 2010 | ASUS P5PE-VM Motherboard
I just reinstalled Windows XP on to my PC and after that the sound is missing. Then I open the box and found sound card RTL 8101L. So, I try to download driver for above device. 10x I try to find and...
I think you made a mistake, if your sound card isn't an additional card, then your sound device is SoundMax AD1888. You can download it from this link :
http://www.getpcmemory.com/drivers/motherboards/download-asus-p5pe-vm-motherboard-windows-xp-drivers/ (Third from the list available) Click on the Wdm0Q1camr.zip. The name you mentioned here Rlt 8101L is not a sound card, it a Lan card. I hope you understand when i make it clear about this. Or else you've additional card (Ad-ons sound card), then it'd be difficult for us to know since you haven't mentioned the device name.
May 28, 2010 | ASUS P5PE-VM Motherboard
Ethernet controller for asus p5pe vm
May 04, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
