Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell E152FPc Monitor powers up, and screen goes blank in 5-10 sec
The power indicator light stays on but the screen goes blank. If I turn it off and then on again, it does the same thing.
  • 1 more comment
  • Ralph Jan 26, 2009
    I left my pc and monitor on for a while. When I tried to get the monitor to "wake", it remained blank. I know it's working as the powersave message appears on the screen, but the monitor doesn't appear to be talking to the computer. Mouse or keyboard clicks don't wake it up. I've tried restarting, I've plugged and unplugged and actually turned off the power to the units and tried restarting, but my monitor won't wake up.
  • Anonymous Feb 10, 2009
    Monitor is new. Goes blank or half the screen goes blank. Won't wake up when it's left on.
  • Anonymous May 25, 2009
    I'm having this monitor problem too, at first, I thought it was with the cable we got, the VGA one that connects to the monitor, but when we got a new cable, the problem re-surfaced, so I'm certain it has to do with the video card or something.
    Scholar:
  • 53 Answers
Ok every one there is a fix the are 4 transistor 2sc5707 and 2 transistorfu9024n and i cap 16v1000uf
if you replace these your problem will be fix for a while but to it better then dell replace the 2sc57o07 with radio shack tip3055 they are 15 amp trans instead of the low 8 amp dell uses they fail because the amps at the test for the transistor is more than 8amps all the correct parts are sold in a kit on ebay look up the 2sc5707 but i recommend upgrading to the tip3055 transistors they are a bigger transistor but you can lay them down and they work great. the capicator can be found at radio 35v1000uf is a good replacment make you monitor better because the new parts are stronger then the originals so no more failures after.
Posted on Feb 20, 2009
At the suggestion of a friend, I turned my powerstrip off, and turned it back on a minute later. Believe it or not, the monitor started working again.
Posted on Feb 07, 2009
  • 3 Answers
I'm working on the same problem now; it could be the power supply or the inverter board, I'm not sure which yet, but when/if I have a solution, I will post my results.
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
I have a Dell E152fpc monitor that turns on and then goes blank after a couple seconds.The power light is on but the screen goes blank. I tried to update the driver from dell but it is impossible to do so...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Jun 25, 2010 | Dell E152FPC (Black) Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Jan 08, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor only stays on for 30 sec. & then goes off then if I remove the power cord & re-power it up it comes on for another 30 sec. then goes back off
Howdy folks. There are only 3 things that can go wrong with a screen. Since you both are experiencing the same symptoms, let's ask the same question: When the screen goes blank, is the power button still green or is it orange? A green light indicates a good power supply and a bad screen. An orange light indicates a bad power supply but a good screen. I used to take them apart and try to fix them but they just aren't worth the trouble because they are so inexpensive nowadays.
Either way, I'm the bearer of bad news. It looks like you'll both be getting new screens. Please don't hold it against me when you rate my solution! ;-)
Jan 04, 2009 | E-Machines eMachines Monitor E15T4
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E172FP 17" LCD Flat Panel Monitor Logo
739 people viewed this question
Alun Cox
