Question about Jandy Pool & Spa
How do i know if the impeller is bad?
I have removed the impeller to inspect for debris. there was some grass and hair, not a lot. So How do I know if it is bad. Also it appears I have some rust on the mechanical seal.
  • 372 Answers
Generally if the impeller looks okay it is good to go. In the event that the pump has run hot (without water) you may find that the back of the impeller, near the seal, has deformed from the heat and it should be replaced.
As for as the seal- when in doubt, change it out. You don't want to risk wrecking a couple hundred dollar motor to save $10 on the seal.
Posted on Jan 20, 2013
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
john224
  • 1378 Answers
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Posted on Jun 13, 2009
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
  • 990 Answers
SOURCE: cleaning the impeller in a sta rite pr2 pump
Don't touch the bolts, they are for removing the motor and the last thing then.
Remove the bolt on the clamp then pry out on the edge of it. Their are three sections and you will pop them off one at a time.
Once inside their five screws holding the difuser in place pull those and your at the impeller.
Posted on Jun 22, 2010
john224
  • 1378 Answers
SOURCE: I am having difficulty removing
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Posted on Nov 08, 2010
Anyone have expierence replacing the impeller on a Toro z master model 74183? This mower vacuums the grass into the rear catcher. The impeller that moves the grass is what I'm referring to.
you have to open bottom to get to impeller once you do that remove the nut and bolt that hold it on you might have use a impeller remover to get off but they hardly ever go bad
Aug 27, 2014 | Garden
My washer won't drain.... I was washing a blanket that was pretty dirty (grass/etc).... I emptied the water from tub, but when I take the back off, I still see water/dirt in plastic tub. I have...
Hello there: if you have disconnected the line tothe drain pump and it appears to be clear check all hoses first and if they are clear then yes i would have to say thatthe pump may be bad But to make sure remove the pump and i you can dissasemble the pump and inspect the internal parts a lot of time you will find lots of things inside of the pump that you cant see Also check the impellers inside of the pump that are used to pump the water out of the machiine these parts are known to wear out over time ok so please check the pump out ok Best regards Mike
Jan 09, 2011 | Kenmore Oasis HE 27062 Top Load Washer
Notices some problem with suction on my Karcher RC3000. Much of the dust remains on the brush and doesn't get sucked in. Service couldn't advise anything. Any ideas?
The air passages through the machine may be plugged, or the impeller (fan) on the motor is slipping on the shaft so that no vacuum is produced. Remove the brush assembly to check the air passage behind it and inspect the brush bearings for collections of thread, string, and hair. Also, inspect the debris collection area for air passage blocking. If there is a filter where the air discharges that might be plugged. Hope some of this helps!
Oct 10, 2010 | Karcher RC3000 Bagless Robotic Vacuum
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
Cleaning the impeller in a sta rite pr2 pump
Jun 21, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Motor problem
It could be a problem with your impeller or your wheels/axles. That is a common, but easily corrected problem, with these automatic pool cleaners. First check the impeller, occasionally hair, leaves, or other material will get caught in the impeller, if this is the vase, take the top grill off by removing the 2 screws from the top. Make sure the transformer is unplugged. Remove the debris and replace the top. Also, you will want to check the front drive wheels and rear idler wheels. Make sure there is no debris or leaves caught in the axle bearings.
May 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
JANDY JHPU2.5 POOL PUMP WILL NOT WORK
Did you separate motor from pump? If not, then there is most likely small debris lodged between impeller vanes which must be removed with a small pick or wire. hope this helps.
Apr 09, 2009 | Pool & Spa
I have versa gold submersible pump, it works intermittently. There is enough water in the pond and it is submerged
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Jan 25, 2009 | NEC Versa Gold Submersible Pump
Flashing f 2
The F2 code indicates the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 14, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Pool & Spa Logo
171 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
