Question about Logitech Harmony 890 LCD Remote Control
Blue screen - says missing license & Battery ADC not calibrated
The remote was working and then the problem above appeared after everything locked up. I removed the battery and re-installed it same message. Remote will not turn off when you push 'OFF"
  • 1 more comment
  • rabell01 Jan 31, 2009
    Frooze first then removed battery then put battery back
    Now getting same error
  • Anonymous Mar 07, 2009
    Word for word same problem here.
  • zenbabydaddy Apr 20, 2009
    Same deal Logitech board says the remote is fried....
    *crosses fingers and hopes warranty is good*
5 Suggested Answers
  • 101 Answers
SOURCE: remote would not respond, took out and put back in
Hardware issue
the memory in your remote is gone
you have to contact logitech
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/ask.php?section=contact&tabs=1,3,2,4,5
Posted on Feb 04, 2010
  • 76 Answers
SOURCE: Harmony 890 remote has solid blue screen
Try putting the remote in 'safe mode' before doing the firmware update. I can't think of anything else you can try, but 'safe mode' --> Firmware update often does the trick. Here's how:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Posted on Mar 06, 2010
  • 101 Answers
SOURCE: MY LOGITECH 890 PRO READS
this is a memory issue, i suggest that you contact logitech to see what they can do for you.
Posted on Mar 18, 2010
  • 52 Answers
SOURCE: 520 remote is locked in safe mode...tried
Hi There,
One solution I have found online for getting the 520 out of safe mode is to follow these steps:
1. Remove the batteries.
2. Hold the '2' button down on the remote.
3. Whilst still holding the '2' button down, replace the batteries.
4. The remote should now boot in normal mode.
Please note, If the 'off' button is held down whilst inserting the batteries the remote starts up into safe mode.
Hope this helps,
James
Posted on Apr 23, 2010
ADC calibration?
Try to go to the control panel and redo your page. If not you can do a system back up to reset it into another date. If you do not know how to do this. You can get remote assistant using our website below....
Windows 7 XP Security Center
Jan 29, 2014 | Westinghouse Computers & Internet
Hello,i recently purchased a graphic equalizer on ebay to work in conjuction with a tape deck, two turntables,two cd players,two mics and a mixer.The model of the unit is a ADC SS-115,i got it home...
I admire your desire to make a nice piece of classic gear whole again but the cost of simply replacing it with a fully functional one is probably less.
Having owned an old Sound Shaper with mechanical sliders I can tell you that you will eventually start to encounter noisy contacts and slider that will drive you crazy. I only used mine for recording and eventually I could never trust the sliders to move without inducing noise. I eventually got an ADC SS-525X with all electronic sliders, Real Time Analyzer/EQ display, 4 curve memories, remote control and life is good.
Surf over to eBay and look around.
There's one SS-525X with no mention of the Remote or calibration mic (which I have but never used anyway). The display lights up in that bright Fluorescent Blue....
http://www.ebay.com/itm/ADC-Sound-Sharper-SS-525X-Equalizer-Analyzer-EQ-SS-525-X-/260853716155?pt=LH_DefaultDomain_0&hash=item3cbc17d4bb
http://www.ebay.com/itm/ADC-Sound-Shaper-SS-325X-Computer-Memory-Frequency-Equaliser-Analyser-/120777825824?pt=LH_DefaultDomain_0&hash=item1c1eeb5e20
Sep 15, 2011 | Audio Players & Recorders
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
My lcd is not working can not set date or fwd,rev but when you calibrate the screen it works. Can use the cam coder with the remote and it works great. Can you please tell what to do
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 21, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Battery ADC not calibrated - what does this mean?
automatic direct current control, try this trick, detached the battery, get a scissor short the batt.terminal of the remote, we try to discharge some small amount of energy that anticipate the temporary memory of your remote then try a new batteries...check
Dec 31, 2009 | Televison & Video
MY LOGITECH 890 PRO READS"BATTERY ADC NOT CALIBRATED" ON SCREEN. WON'T DO ANYTHING.
Dec 14, 2009 | Logitech Harmony 890 LCD Remote Control
REMOTE LITES UP BUT WILL NOT WORK ANYTHING
you need to program it, if it has a usb cable connection you will need to install the software and plug it in to program.
Apr 21, 2009 | Logitech Harmony 890 LCD Remote Control
Code for a Gateway ADC-320 needed
Hi chris_vau888
You could try these codes :- 1100, 1104, 1185, 1221. If none of those work you could try the philips code lookup finder at :- http://www.urc.philips.com/ You will need the remote model number, either from the front of the remote or in the battery compartment.
Hope this helps,
Mark.
Mar 29, 2009 | Gateway ADC-320 DVD Player
Logitech Harmony 890 LCD Remote Control Logo
1,310 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
