Question about Bush Televison & Video
Why does my Bush LED24970 DVDFHD television seem to seize up for a few seconds soon after being switched on. The picture goes pixellated and the sound disappears and then it all comes back on again. It has always done this since I purchased it in 2012. I have recently re-tuned it but that has made no difference.
  • Christine Wilks Jan 22, 2013
    Further to my earlier question. Is this a serious problem which might need repairs at some stage? If so perhaps I should take the set back to the retailer and ask for another one while it's still under guarantee. Unless all these models do this - but I need someone else with the problem to confirm if this is the case.
premtech
  • 934 Answers
SOURCE: picture limited to a single pixel horizontal line, sound fine
This is actuall quite a simple problem... What you have explained here is a loss of vertical deflection. By the symptoms you described, working now and not working it's most likely the the vertical IC an LA7847-E has probably become ring-cracked at the point where the pins are soldered to the pc board. Depending on how long it has been allowed to arc the IC may have failed also, but they are not terribly expensive or difficult to repair - at least not here in the shop. The main board has to be removed. Locate the vertical IC - it will be mounted to a metal heat sink and the IC will be stamped LA7847. Then turn the board over and inspect where the pins are soldered to the foil side of the board. One or more will look ring cracked or fractured all the way around the pin. At this point you have two options, carefully reflow solder over each pin and put it back together or replace the IC by de-soldering it and removing it from it's heatsink. remember to use a good heat sink grease when applying the new IC.. There should also be a couple of caps in pretty close proximity to that IC... One should be about 50v/100uf and in the shop here we test em all... You might also just replace that one for good measure - they're not expensive either... If any of this sounds too complicated take it to a reputable shop and pick it up in a day or two.. Job shouldn't be that expensive or time consuming. My record in the shop here for doing those is 15 in one day. Average cost for that set, we charge is under $100 if you bring it in and pick it up.. Hope this helps Bill If you're calling around to the repair shops you might just ask if they have that IC on-hand or if they will need to order it..
Posted on Jun 07, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
Jannarama
  • 14 Answers
SOURCE: Problem with sound and picture
If you have Cox Cable, and are using a Scientific Atlanta box, AND have "On Demand", and the volume suddenly goes out, turn your cable to the "on demand" channel (in Phoenix, AZ it's channel 1) and that usually restores the sound.
It's a known issue, and so far this is about the only solution that works quickly.
Posted on Mar 19, 2009
I have a 3.5 year old Bush LED24970. Recent;y it has decided to turn down the volume to zero, 3 or 4 minutes after switching on. I've tried all I can think of. What can be done? JP
check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jun 15, 2016 | Bush Televison & Video
Bush BU102ZRH50 COMES ON FEW SECONDS PICTURE FREEZES
Corrupted firmware. A firmware update is necessary. Contact any service technician; or the authorized service center for Bush.
Feb 25, 2015 | Bush Televison & Video
Bush good picture but no sound
This may help if the tv as a 3.5 ear phone socket try your earphones & see if the sound works if it do's then its prob the switch in the ear phone socket that's @ fault and norm inserting & pulling out the ear phone plug a few times can clear it
Sep 28, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
Blurry picture in top quarter of screen
this is caused by the panel's edge contacts coming loose(delaminating). would have to replace panel(approx. 1500.00 usd.)
Mar 01, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
Picture up side down
change the verticle cables on the deflection coil on the tube.
note just the verticle cables ( verticle has only two cables)
what is happening is that current is reversed.
get it to some body a tech.
my tv gave me a similar problem.
Feb 08, 2009 | Bush 2871NTX 28" TV
BUSH LCD 17TV004 picture goes off!!!
if yo know how to solder , re solder your tv, second adjust the IF transformer by using the plastic or wood stick. IF transformer is looks like a cube made of metal with an adjustment screw at the top. try to adjust it and observe what happen.
Oct 16, 2008 | Bush 5693D 24" TV
Bush rf6683vpl
yes ,your tv need for repair, but if you know how to solder , try to solder your tv but be careful o short circuit coz it may damage your system.
Sep 06, 2008 | Bush 5693D 24" TV
Toshiba 62HM95 has sound, but picture turns off after a few seconds
Did you change the light engine? If not they are very easy to do, you can do it yourself.
Feb 12, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
51 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
