Question about Epson Stylus Photo RX520/RX530
NO RESPONSE FROM SCANNER
Message box says 'no response from scanner. Make sure the scanner is on and properly connected. If using the Transparency Unit, remove the Reflective Document Mat.
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
My computer and scanner intermittently can't communicate. I am mainly scanning in photo transparencies at the moment - four at a time, using the "professional" setting in the software. Typically it...
I had that problem. I was using the USB ports that came with my computer. I added an IDE USB card in my computer. I haven't had a problem since.
JNHV23
Jan 10, 2010 | Epson Perfection 3170 Flatbed Scanner
Once you turn the scanner on, select scan document, the page(s) will scan, go to the file designated, then when you try scanning again it says that the scanner is busy. Pressing the ok button then says...
this could be down to the scanner connection not being set properly go to the scanner settings check that the port or connection is set to usb if connected directly to computer or if you are using parrallel port set to this the reason you are getting a hang is the document is being saved and then trying to connect to computer or printer and it cant communicate so the docs go no where by turning off you reset it again... good luck A
Jun 10, 2009 | HP Office Equipment & Supplies
Can't use scanner
  • Hi there,
    • Unplug the Scanner cable from the computer.
    • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
    • restart the computer
    • try to download drivers from the website
    • after installing drivers and software it will ask you to connect the Scanner.
    • then you can connect the Scanner and and try to Scan.
    Hope this help. Please Rate My Response! Thanks!
    GF
Apr 27, 2009 | Office Equipment & Supplies
Can't scan properly. Scanned item fragmented
PREM
Mar 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Computers & Internet Logo
29 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
