Question about Ridgid Tri-Stack 5-Gal. Portable Electric Steel Orange Air Compressor
I have a rigid tri-stack compressor and when you turn it on with no air in the tank it starts no problem and run up to full pressure and shuts down howeveras soon as it stops it seems like it trys to start again immediatly and you can hear the motor hum until it pops the overload. Im not sure if its the switch doing this or the one way valve not working. What do you think.
  • 9 Answers
SOURCE: Have rigid twin stack air compressor. Only keeps
possiably the " reed valves under the head are not closeing off all the way. These may be bent or somehow distorted their tension most of the time from exsesive heat. Good luck
Posted on May 19, 2009
compman66
  • 169 Answers
SOURCE: the compressor fills up with air fine.AS i start
yes sounds like a defective pressure regulator, I would order a new one and replace it, pay attention to the flow direction when installing the new one, they have an arrow on them to indicate correct flow direction.
Posted on Nov 26, 2009
SOURCE: Replaced pressure control switch on Ridgid OF45150
False alarm. The pressure control switch just needed to be adjusted using set screw on top.
Posted on Feb 05, 2010
SOURCE: i have a two year
its probably the capacitor #079027007072 $10.58
Posted on Feb 19, 2011
  • 4 Answers
SOURCE: Our Rigid air compressor constantly
It is a junk compressor, but you want to make sure you're using a heavy duty enough cord and an outlet with good power to run it. I have a RolAir that is a power hog, I usually need to check several outlets on a jobsite to find one strong enough to start my compressor. Usually the closer to the electrical panel/service you go the better the power is.
Posted on Jul 17, 2011
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Builds up air pressure ,motor shuts down
We are distributors of all plastic materials, including complete fabrication of plastic parts, components and assembles like Acrylic sheets, polycarbonate sheet and UHMW.
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
http://www.plastic-craft.com/novus-plastic-polish-buffing-kit.html
Aug 09, 2011 | Campbell Hausfeld 04 Gallon Twin Stack...
The rigid double stack air compressor fills up with air fine.When i start to use it no air pressure comes out.
There has to be a restriction where the air leaves the compressor. Remove the supply fitting and check to make sure the hole is open into the tank. Also look to see if the fitting isn't blocked. If none of this is the case check the air line for blockage and also check to make sure there is no shut off valve in the line that isn't open.
Mar 13, 2011 | Air Tools & Compressors
With full tank of air, compressor turns over slow then kicks out motor reset button
Hi, my name is John. Welcome to FixYa. Check your pressure switch, it,s only supposed to build up to 135 psi and shut off, then back on when the pressure gets below 105 psi, check the oil level. thanks for choosing FixYa. ..John
Nov 23, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
The compressor fills up with air fine.AS i start
I would check the pressure switch. It probably has bad contacts in it. You could try to clean the contacts first before replacing the unit.
Nov 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
When tank is low on pressure, the motor cuts in but compressor struggles to turn and trips.
some compressors require an air release that drains the pump head when the compressor reaches full pressure if this is not working the compressor tries to start with full pressure on the pistons which is hard on the motor. If you always heard a small release of air when the compressor shut off yours probably had this feature. drain all the air out and if it starts fine that may be where the problem is. If its one of the smaller oiless ones the motor start capacitor is probably bad
Jul 10, 2009 | Psi Air Tools & Compressors
Starter valve dont close hatachi ec119sa (air compressor)
The start valve gives your motor a running start before the motor begins to load as the pressure increases from an empty tank. The motor strain is more profound when there is pressure in the tank. If you plug the valve, the motor will instantly encounter a heavy load because it has to force air into a partially filled tank. This extra load without the valve will shorten the life of the capacitors and motor windings. There could be two problems with your unit that can revealed by test. What actually closes the valve is a certain volume of air produced by the compressor. If the compressor is not pumping to full efficiency or there are leaks in the discharge hose the valve will not close. Or the valve is faulty. With an empty tank, plug the valve and run compressor and test airline for leaks with soapy water. If no leaks, empty tank of air and restart compressor and take note of the amount of time it takes to fill the tanks to shut off. If it takes an unusually long time to fill, then the compressor probably has valve problems causing low air volume. If the compressor fills to shut off in a short time frame as compared to a similar model then replace the valve. Leaking valves in the head will also cause the pump and discharge tube to run very hot. Parts are available at www.toolpartsdirect.com Good luck with your repair.
Apr 01, 2009 | Hitachi EC119SA Twin-Stack Air Compressor...
Air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Mar 22, 2009 | Campbell Hausfeld Air Tools & Compressors
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Ridgid Tri-Stack 5-Gal. Portable Electric Steel Orange Air Compressor Logo
121 people viewed this question
Top Ridgid Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
