Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Yamaha ef2800I won't start
I have put fresh gas cleaned the carborator and the engine will not start.
3 Suggested Answers
  • 3 Answers
SOURCE: I have ef2800i yamaha generator that after warm up
Replace the fuel and check to see if cabel is adjusted correctly over adjustment will flood it everytime
Posted on Mar 10, 2011
  • 28 Answers
SOURCE: Yamaha EF2800i generator will only run with the
Whenever storing the generator for any length of time after use, it should be allowed to run out the gas from the carburetor by first shuttinig off the fuel petcock, to avoid the gas in the float bowl from deteriorating and gumming up the small idle passages. With the mandated ethanol additives that are used, the gas breaks down much faster than pure gasoline, so it's more crucial to do this prestorage maintenance.
Luckily the Yamaha incorporates a fuel petcock to make this simple to do, unlike other generators that don't enable the fuel to be turned off independently of the engine.
Posted on Apr 07, 2012
2007 TTR Yamaha won't start
you will probably need to clean the carb there is a you tube video on how to remove and clean
Jun 09, 2012 | Yamaha TT-R 125 L Motorcycles
Why is my 95' yamaha virago 250 stalling out when I get on the throttle
http://www.repairmanual.com/product/yamaha-virago-xv250-v-star-250-motorcycle-service-manual-cyclepedia-printed/
Apr 17, 2012 | 1995 Yamaha Xv 250 Virago S
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Sears intek 20 hp, fresh gas, filters air and gas, oil, and plug still won't start where should small valve and screw adjustment be set to, may be the problem don't know. won't stay running...
If you have not been putting gas treatment in your gas to treat the ethenol they have been putting into the gas its a good chance its the needle valve in the carborator. If you live in a state that does not add ethenol to the gas disregard this advise.
Jul 10, 2011 | Garden
Yamaha EF2800i generator will only run with the choke engaged. Will not hold load. Unit was in storage for 8 months while I was out of country. Added fresh gas, checked spark plug, let warm up for...
Remove & Check Float bowl on carburettor for any foreign matter. If there is any, it could have got into jets causing engine to run lean (only run with choke) and not be able to carry load in this state. A cleanout of the carby would not hurt and check the fuel tank for any sediment as well.
Aug 24, 2010 | Yamaha 2500 Watt Industrial Inverter...
Erratic Sputtering...
Three years with that few miles sounds like a good candidate for bad gas. I would start by taking the carb off and cleaning it really well with carb cleaner.
May 24, 2009 | 2006 Yamaha V Star 1100 Silverado
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
143 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
