Question about Alesis Q49 USB/MIDI Keyboard Controller
Keys working explanation or user guide
Can somone please explain how the keys work with their above inputs ? From my musicmaker (Magix) i can import sounds to play with, but how can i get the sounds that originally come out of my Q49 ? On the keybord there is 1-16 midi keys, but how does it work ? i need a manual or user guide to work with the different things that are standard in my device. Thanks
    Problem Solver:
  • 17 Answers
You need to load software on your computer that contains midi sounds - sampletank, Reaktor, etc. Make sure everything is set to Midi channel 1.
Posted on Oct 16, 2013
3 Suggested Answers
  • 5603 Answers
SOURCE: I have an alesis q49 and the usb port in the back
MIDI would be slower and would depend on the software and drivers as far as it working. Just have the USB jack replaced. Jacks are not very expensive.
Posted on Jun 16, 2011
  • 5603 Answers
SOURCE: Hi team! I've just bought an Alesis Q49
That is what you can use transpose for... Now the truth is revealed: What transpose does is JUST move the notes (including the black keys) up and down the keyboard... that is ALL transpose does... so if you transpose +1 when you hit C the keyboard emits C# and hitting C# emits D and hitting D emits D#, etc... Now with trsnspose set at -2, hitting C results in B flat being emitted and for instance hit a G at transpose -2 results in F being emitted... Simple isn't it? For MIDI all they do is add the transpose to the note number. Don't forget that the black keys are counted as well as the white ones.
Posted on Jul 13, 2011
Testimonial: "Very clearly explained, thank you so very very much, team, 'twas such a big help."
Input works, output does not.
Why do so many people assume we know what you are talking about? Please give as much detail as possible when asking questions. What is the equipment you are talking about, model numbers too, what are you trying to do and describe precisely the issue you are having.
The question above seems to warrant the answer " Diagnosis: You are constipated. Solution: Take a laxative."
May 11, 2016 | Music
My zoom g1x theres no sound.all power are working lcd light are on.but the sound cannot come out.can any one help me..
What letters / numbers that appears on the screen?
If the display is normal, and you can switch to other banks, and can edit each bank, then the problem of no sound, is at the pre-amp IC input, output amp, or CODEC converter.
This is the overall image of G1X inside.zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-0.jpg Next, we zoom-in the middle of picture above.
See the next picture.
IC2 (left) is input pre-amp IC (NJM2100).
IC4 (middle) is the CODEC IC (WM8734).
IC5 (right) is the IC output (NJU7082).zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-1.jpg
Test whether the input IC is working normally, turn ON G1X, plug the guitar, go to BYPASS/TUNER menu. When the TUNER function could work, certainly input IC is not damaged.
Means only two possibilities, namely CODEC and output IC. That is not easily tested, except in specific ways.
May also, there are problems in the input / output socket.
Turn ON G1X. Try the following (see figure below):
  • Test the output socket. Touch pin output socket (right red arrow) with finger / screwdriver / whatever. If sound is heard in the amplifier, the output socket is normal.
  • Test the input socket, Same as above. (left red arrow). (if this happen in this point, problem is clear).
NOTES:
If lcd light are on (as you say), but appearing G1 or d5 or bt, and the system are hang / frozen, this is a different issue to the one described above,and dealt with in different ways too.
References IC datasheet:
NJM2100.
http://www.njr.com/semicon/PDF/NJM2100_E.pdf
NJU7082
http://www.datasheetarchive.com/dlmain/Datasheets-22/DSA-439015.pdf
WM8734 http://www.cirrus.com/en/pubs/proDatasheet/WM8734_v4.4.pdf
Sep 10, 2015 | Zoom Music
Please explain possible uses for the aux input and what knob controls it.
We would need to know the make and model of the mixer youre asking about.
May 10, 2015 | Music
No sound from amp
First of all it is important that the amplifier must work to produce the output with an input signal. So disconnect and check with an audio test signal on the input line and at the coupling capacitor to the input. If this is fine then the fault is only the connection and it is possible that the input line has shorted and so the input is not acting. But if other inputs are working the connectors must be rewired and soldered once again without any bridging.
Dec 07, 2011 | Kustom KMA Series 100 watt Mixer Amplifier
I AM NEW TO THE COMPRESSION WORLD COULD YOU PLEASE
Compression (not to be confused with data compression such as that used when storing data) is used to reduce the gain automatically when the input level exceeds a certain level. There is usually an attack setup which sets the rate and delay at which the reduction occurs. Use of compression causes distortion of the waveform usually to prevent clipping. It is often used if vocalists go from normal level to yelling and the sound man can't react fast enough to keep the level from going into clipping. When the level exceeds a set level the gain is reduced at a rate the user usually sets.
Think of it as an "automatic volume control" that kicks in to prevent clipping.
Dec 27, 2010 | DBX 266xL Compressor Gate Processor with...
Our brand new Korg SP170 worked great for several days. Today all the C keys and all the E keys quit making any sound. We checked all cords and connections, turned it off a bit and back on, with it plugged...
There probably is a cable or connection inside that is loose... The keys are scanned as a matrix so some connections are in common...
HOWEVER: Since you have had it several days DO NOT delay, call for warranty service. This is not a DIY repair unless you are adept and comfortable with electronics.
Dec 10, 2010 | Korg SP170BK 88-key Digital Slab Piano...
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Roland AC-60 Amp input impedances ?
I will solve the mystery...
The impedance varies depending on how you connect. It would be too complicated to explain the impedance to the average person.
From the schematic we have the TRS 1/4 inch jack having basically 100K and parallel 220 pf cap to ground EACH signal line and 10K resistance between. (The TRS jack if used disconnects the XLR and its components)
If one uses the XLR jack, one has an ADDITIONAL 100K each side in parrallel to ground PLUS an ADDITIONAL 2.2K resistor shunting between.
In ADDITION to the above, there is effectively 160K ohms to ground each side that is the input resistance to the input OP-AMP.
The effective impedance will depend on how and where you measure it.
Not sure what peizo you are using... For one on wife's violin we go into a X2 wireless which has about 1.6 Megohm. The receiver of course is fairly low impedance drive to the amp.
For the violin (Autolycus) pickup and others, severe distortion of the waveform existed when run directely into most amps and of course long cables worsened it at the high frequencies.
May 20, 2010 | Roland Ac60 Acoustic Chorus Guitar...
Describe how a truss rod works. or sites w/detailed info on setup
Have a look at www.stewmac.com. There is a good edscription of what you want to know at www.fretnotguitarrepair.com.
Apr 02, 2009 | Fender Squier Std Strat Mn Car
Alesis Q49 USB/MIDI Keyboard Controller Logo
150 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
