I am reading in the manual of the Samsung that i have the ability to change the AV mode of the camcorder to IN or OUT, by entering the menu and finding the correct line that sais " AV IN/OUT " , in order to record from TV. I turn my camcorder to "PLAYER" mode, i go to menu / AV...but there is no " AV IN/OUT " command...I see in the manual that it should be in the bottom of all AV commands, but there is nothing there...
SOURCE: lcd problem
Sounds like you have either a problem with the CCD block or on the mainboard where the encode/decode section is. If it is the CCD block it is defective or you have a loose or dirty connection on the ribbon cable from the CCD block. In record mode you are seeing the video E/E, which means you are looking at the video from the CCD block which has passed through the mainboard. That would explain the lines on the viewfinder. When you playback a tape you are looking at the recorded signal, but it also passes through the mainboard. It is not clear whether the tapes you are talking about playing were pre-recorded previously (prior to this problem) and played previously, with no lines present. If they were recorde previously, played back previously with no lines, and not re-recorded. They should be OK provided the problem is not tape damage. Since you say that all tapes do it, I would think it is not tape damage. The best place to start, to sort out the problem, would be to locate a known good camcorder and try your tapes in it. If they play fine the problem is on the mainboard but after the record circuitry, ie. only in the playback circuitry. If they have the lines the problem could still be on the mainboard but also could be the CCD issue I talked about. This is a tough problem to isolate and will take a good repair tech. If you are not familiar with troubleshooting camcorders you will need to locate a reputable and experienced repair facility. First you should do the test I mentioned on a known good camcorder as this will help a repair tech make a diagnosis. If there are no repair shops in your area here are several which offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck.
SOURCE: i have a samsung vp-w90
The iris is stuck in the closed position. This could be released by a simple tap to the side, but be careful. If a slight tap does not release it, then the camera will need to be disassembled and the iris cleaned and re-assembled.
Dan
SOURCE: Samsung Digital Camcorder VP-D351
hi..Please to pass on the remedy..I had this two weeks ago.. lcd ribbon is brocken.. breaks over time with being opened and closed.. Part available form partmaster.co.uk.. part no..SAMAD9706489A.. lcd fpc ***. easy to replce ..take you time and try yourself.. if i can help with instructions [email protected].. cost of ribon £11.49.. GOOD LUCK STEF.
SOURCE: Samsung VP-D31 Mini DV Digital Camcorder recording black screen
I have a brand new VP-D31. It still has the protector on the screen. I acquired this (legally!) but it has no charger,cables, battery or any etcs. I got it from the Police Auctions and was too ignorant to understand what I was getting. The item was obviously stolen from a store shelf - hence no bits. How about you buy it from me?
SOURCE: using sc-dx103...can't delete video on disc mode.....
Change the mode then hit the menu button
