Question about Yamaha 2011 FX Nytro XTX
2011 yamaha nytro xtx rear suspension springs sags
  • 2712 Answers
SOURCE: Trying to set my sag
97 cr250 came with a yellow spring stock 5.3. You need to drop down in rate. Run a 5.2. That rate ranges for a rider between 165 to 180
Posted on Nov 10, 2008
  • 149 Answers
SOURCE: Can the rear suspension of a yamaha royale 1984 be
is it a single shok or does it have 2
Posted on Aug 30, 2009
  • 8404 Answers
SOURCE: I want to know the poundage of the rear suspension
If you are bottoming out a lot, turn it up a notch. If it never bottoms out and is a stiff ride, turn it down a notch.
Posted on Nov 30, 2009
  • 3 Answers
SOURCE: How to adjust rear spring coil suspension on (from
turn the coil lock nut counter clockwise to loosten
Posted on May 14, 2010
sisadsl
  • 1508 Answers
SOURCE: Hi..Im looking to get my 2011 KX450F suspension
Your going to have to keep working through the manual, it has way more info than can be typed here.
If it feels too hard and youre out of adjustment, you need to try a softer spring.
you can try anything that works for you, forks up, down, more or less sag, there is no quick simple fix and what one rider says is good may not work for another, and a different track may change things completely.
harsh front- reduce the compression damping, high speed or low speed depending on how far the forks are compressing or lighter oil, if you go too light it may try to tank slap and need a steering damper.
If you use all the travel, then the springs are close to correct, it can even bottom out a little on the biggest jumps
One step at a time and take notes of each change, including how it felt and what the track was like.. this is the way to see what works, and give you the option to easily change it back if it doesnt
Posted on May 23, 2011
My back end of my snowmobile won't come up unless i pull it up, whats wrong
I would look at your SHOCK, SPRINGS, HARDWARE. I would break out the PB BLASTER and lube it up and possibly get some HEAT onto some of the parts to get some movement. GREASE, BOUNCE, BOUNCE, BOUNCE... Something in your Suspension is not moving freely...
Nov 21, 2014 | Yamaha 2008 FX Nytro Base
Fault codes for a yamaha nytro
Hi Terry, which year is your Yamaha Nytro and is it a XTX or other ?
Does it start while your codes are displayed ?
Follow the link below and you will find the error code definitions.
http://192.168.1.5/downloads/snowmobiles/Yamaha-Nytro/Nytro-Fault-codes-table/TY%204%20Stroke%20-%20Totallyamaha_%20View%20topic%20-%20Nytro%20Fault%20Codes,%20Relay%20Location,%20Fuse%20Location%20Diagrams.pdf
Mar 09, 2014 | Yamaha 2009 FX Nytro XTX
What makes the rear wheel lean inward on a 93 Buick regal?
Your rear springs are probably the cause. Over time the springs get weak and cause the rear to sag. If you have independent suspension, which the 93 does, it will cause the tires to lean in a little. This will also cause the tires to prematurely wear on the inside. I think that car has leaf springs not coil springs. Your shocks are probably shot also, but that would not make it sag, that would just make the car very bouncy.
Feb 10, 2014 | Cars & Trucks
How to change rear springs on 2011 nytro xtx
what is the name and model,rate these for clean solution
Jan 20, 2013 | Motorcycles
When my envoy sits overnight my rearend drops down
There has been a service bulletin for that type of concern. Here is what it states.
Suspension - Rear Suspension Is Low/Sagging/Uneven
Notes
ENGINEERING INFORMATION
Bulletin No.: 06-03-09-006B
Date: December 15, 2008
Subject:
EI06006 - Rear Suspension Uneven, Sagging, Low (Recalibrate Air Spring Sensor)
Models:
2006-2007 Buick Rainier
2006-2007 Chevrolet TrailBlazer SS
2006-2007 GMC Envoy, Envoy XL
2006-2007 Saab 9-7X
with Suspension Pkg - Rear Load Leveling (RPO G67)
Supercede:
This bulletin is being revised to update the labor operation in the warranty information. Please discard Corporate Bulletin Number 06-03-09-006A (Section 03 - Suspension).
Condition
Some customers may comment on the rear suspension being uneven or sagging.
Correction
DO NOT REPLACE THE COMPRESSOR.
Based on technician feedback, engineering has determined that the customer's concern can be corrected by recalibrating the air spring sensor. Refer to the Trim Height Uneven or Low diagnostics and Air Spring Sensor Calibration procedure found in SI.
Nov 29, 2011 | 2004 GMC Envoy
2011 KTM 50 SX suspension settings
Hi, Couchcourvil the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KTM 50 suspension help
Mini Bikes
KTM 50 SX Repair Manual
https://www.partsfish.com/page/oem-parts-for-ktm
KTM 50 SX Owner Manual
Nov 05, 2017 | 2011 KTM 50 SX
Having trouble setting my suspension on my yz the sag is set cant get the rest to balence out for me im bout 150lbs does anyone noe a good setting for that weight?
In general you want to set sag for around 25-30% of the total suspension travel. Most dirt bikes are around 300mm of travel so set your sag (race sag) at around 85-90mm. Once you have done that, check the sag (static sag) without rider. It should be around 5% or so. If the static sag is more than 5% your spring is too hard. If it's less than 5% or zero then your spring is too light. This applies to both front and rear suspension.
These setting's don't have to be exact but it will definitely get you in the ballpark and help your bike to be balanced between front and rear. Also when you check race sag, you need to be in your natural riding position standing on the pegs wearing all your riding gear.
Feb 21, 2011 | Yamaha YZ 125 Motorcycles
03 yz 125 suspension set-up
You need to start with the spring sag. You need of 3 inches of sag front and rear with you on it and all of your riding gear on. you will need a friends help to measure for you.
May 22, 2009 | 2003 Yamaha YZ 125
Yamaha 2011 FX Nytro XTX Logo
96 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Gene Tuck
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
