Question about Whirlpool Washing Machines
The timer on my whirlpool washing machine model LSN8244AW0 does not stop when it comes to stop mode on the dial with lid down.
Can hear the timer continue to run as it goes by the stop mode on the dial. Pushing the timer dial button will stop or opening the lid will stop.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the timer. Here is the part to order.
Posted on Jan 20, 2013
  • Brett Duernberger Jan 20, 2013
    Thanks for your reply. Was thinking the timer may be bad but want to give you a couple of other details to see if you still think the same. If you rotate the timer dial to the regular wash cycle and then pull out the knob like normal, the water will start to fill but the agitation will start to work right away unless you leave the lid open. With the lid open, it works normally and will fill until until it reaches the correct water level and then starts the agitation. However if you close the lid anytime during the fill cycle, it will start agitating. It works exactly the same (incorrectly) during the rinse cycle. Once rinse is complete it will do the drain properly as long as the lid is closed. If lid is open during drain, it reacts properly with the switch not allowing motion. After drain and spin you have to push the timer dial in to stop the machine otherwise it will keep going and start filling with water again even if you leave the lid open. In other words, the only way to stop the timer is by pushing in the button. It keeps going right past the red stop dashes on the dial. Looking forward to your additional feedback.
  • Richard Roth
    Richard Roth Jan 20, 2013
    Yes, it is definitely the timer. Sound like there is a stuck contact inside of it. replace that timer and all should be good. Keep me posted!
AlmostBob
  • 550 Answers
SOURCE: washing machine
remove the left and right edge trims on the control panel
remove the phillips screws under the edge trims
raise control panel ~1 inch and flip over backwards.
  • ensure air tube is attached( water level sensor operates off air tube from bottom of drum to control body, (bottom is not loose or there would be water all over the floor))
  • Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
  • ensure wires are connected to control body.
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed just dont shock yourself on the cable connectors
  6. test, adjust, test adjust. (water level switch may need to be flicked hi-med & back to test adjustment
  7. if no effect replace water level sensor body
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
Posted on Jul 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Posted on Apr 06, 2009
honeymokey
  • 3113 Answers
SOURCE: Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Posted on Apr 14, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Our Whirlpool washer LA 8860 XWQO just stopped during the wash cycle. No noise, no smoke, no nothing. We tested the outlet and there is power to the machine. Turning the dial to other settings does...
Could be a bad lid switch. As you lift the lid up and down can you hear the lid switch click on and off?
If you can hear it click chances are it's good. If you can't hear it click on and off that's your problem.
Aug 03, 2011 | Whirlpool Washing Machines
Washing machine circular timer switch stops with load of wash and water inside during the first cycle; circular timer dial also stops moving clockwise. My guess is a defective motor/timer - are they all...
If you are able to advance the timer and get the machine to run and finish the cycle, then yes the timer is your most likely culprit, and yes the timer motor and timer are all one piece.
However if it does not complete the cycle and you are unable to drain the water out, your problem could be with the lid switch assembly, not the timer. Check the switch by looking for a tab on the right side of the lid that would (when the lid is closed) contact the switch mounted under the top of the cabinet. you should hear an audible click when the switch is depressed.
If you find it is the switch, please let me know and I will give you instructions on how to replace it.
Oct 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Had new timer and new water gauge and still stops between cycles and won't drain
what is the model number?if it's an older machine you could have a broken lid switch or a broken motor coupling.close the lid down and open it a few inches,do this a few times,if you don't hear a clicking sound you have a broken lid switch,if you can hear the motor running and the machine isn't moving you broke the motor coupling.let me know how old it is and the model number
Oct 02, 2010 | Whirlpool Washing Machines
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
