Question about Maytag M7DH45B2A Dehumidifier
Leaking water I've had this dehumidifier for a few years and it's been fine. A couple days ago I emptied it and afterwards, it starting leaking. The unit had stranded water in it and I had to tip it over into a sink to drain it out. I've cleaned the filter. It runs, but it leaks water all over the floor from the bottom.
  • Anonymous Mar 22, 2014
    Water leaking out of bottom of brand new dehumidifier
  • 105 Answers
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Posted on Jul 17, 2007
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
Jul 13, 2016 | Windchaser Dehumidifiers
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
I have a Windchaser dehumidifier Model WDH928. The problem is that it does not automatically shut off when the tank is full. The water just flows over the tank and out. I've had this for years and it...
The float valve sensor in the bucket is either stuck in the down position or has broken entirely. Accessing the interior of the tank is the only way to know. I would recommend that you use a continual drain hose, but that is not recommended, as the coils need some water in the tank to cool.
The real downside is, that Windchaser has been out of business (phones disconnected, website down, etc) for several months and parts are extremely had to find.
I hope I was of some help to you. Thanks for choosing FixYa.
Aug 15, 2011 | Windchaser MDH-W Dehumidifier
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
Dehumidifier leakage
My dehumidifier leaked after about one year of perfect operation. I unscrewed the face plate exposing the cooling grill and found out that debris was blocking the drainage hole that fed into the water bucket. The debris came from zip ties used to bunch some wires together. Apparently they got brittle (from the constant cooling and warming?), fell apart and managed to make it's way to the drainage hole. Cleared it out and worked fine again.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
463 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
