Question about Kitchen Appliances - Others
Toastmaster toaster only works if i hold lever down
  • 979 Answers
There is a catch on the lever that is loose or broken. You may have to dissemble it to find out. If broken, just order the part. It is pretty easy to put on.
Posted on Jan 29, 2013
SOURCE: Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Posted on Mar 14, 2008
  • 87 Answers
SOURCE: vintage toastmaster toaster
you will need to adjust the heat switch to a hotter temp. then pull it down. its the slider arm located below the lever.
Posted on Jul 12, 2008
cactus bob
  • 267 Answers
SOURCE: Toastmaster T80BC toaster will not engage when plugged in.
why do you think cancel button is broken , is it stuck ? if not you gave a bad control board . so recheck the button , and pick at it to pop back to normal . if you need a board your out of luck , no parts are made for toasters anymore . its a toss it and get a new one world . if you get 4 years out of todays toasters your doing good Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 09, 2009
SOURCE: Toaster won't stay down. Toastmaster Toaster
The contacts on my magnetic lock (lever) had some crumbs and build up on it. I had to take it apart but just cleaning it made mine work fine again.
Posted on Dec 23, 2009
caroldon
  • 17130 Answers
SOURCE: toaster will not switch on.
Two possibilities that the switch down is defective or the latch down is not working.
So this can be probed if you can remove the plug and check for bits of dirt from crumps that have got entangled and burned into the switch or the latch.
if you can open the toaster remove and see if there is dirt that has clogged into this section. If you have a multimeter check the continuity of the toaster coil and the bi-metal switch which has to latch off when the set temperature is reached. If the coil is open , it will be better to do away with this than to repair by connecting the open wires which might last for some more time.
If the switch contacts are faulty clean and use a anti-grease spray( WD40) to clean up.
reset and connect making sure that the leads are not shorted to the body .
Posted on Dec 14, 2010
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
I have a toastmaster t80bc and the clear plastic part that locks down the handle on the inside popped off, anyone have a pic or diagram of how it goes back on. Nothing is broke it just came off and its...
yes I got the same problem, I Fix myself.(model T80BC)
unplug main power cable, remove top cover (remove 4 screw from the bottom and knob from the side)disconnect control panel cable from main board.look at the attached picture.in the photo close to power cable connector will see a slot
(look at the black arrow mark pointed ).insert plastic switch to this slot, make sure both side properly mounted.then move toaster push down lever up and down. it should move as usual without any obstruction. now put back control panel cable and top cover,knob,and all the screws. plug cable into the power,it should work.
see switch
Feb 26, 2010 | Toastmaster Kitchen Appliances - Others
Sep 21, 2009 | Kitchen Appliances - Others
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
Mar 08, 2009 | Kitchen Appliances - Others
Vintage toastmaster toaster
Jul 07, 2008 | Kitchen Appliances - Others
Toaster lever
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Toastmaster toaster
thermostat seems to have given way, needs replacement
Sep 25, 2007 | Toastmaster TP409 4-Slice Toaster
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Kitchen Appliances - Others Logo
104 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
