Question about Maytag MFD2561KES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag refrigerator model number mfd2561kes all lights on on temp.control panel it is showing 8.8.8. in the temp. and all the other lights are lit up, I tried unpluging an repluging but it didnt change they stayed lit when I held down the door close buttons.
  • 356 Answers
I suspect that the controller card is bad.
Posted on Jan 20, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
  • 1891 Answers
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Posted on Apr 19, 2010
Testimonial: "Thank you. We will work on that and see what happens. "
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
heatman101
  • 43501 Answers
SOURCE: My refrigerator has stopped cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 02, 2010
Maytag Refrigerator Model Model #MFI2568AES
This a common problem with these units the high voltage in the main control board is the problem, the main control board in the back will need to be replaced. This runs about 250 dollars for the part. You can order it from this link.
http://www.repairclinic.com/Maytag-Refrigerator-Model-MFI2568AES-ID-657261-Parts?n=2
Nov 09, 2013 | Refrigerators
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
I have model # Maytag MFD2561KES french door refrigerator. The ice maker works sporadically. I do not see a pattern around when & why it chooses to work. I have rearranged the items in the...
This could be a tricky problem to analyze and fix, since it seems to be an intermittent problem. On the following website is a list of things that can cause the icemaker to not make ice, and it is where you should start, as far as analyzing and troubleshooting the unit.
Of course, you should make sure your condensor coils are clean, and that the evaporator coils are not icing up.
Here is the site: http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
The following site has diagrams and parts lists for your unit:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170926
In diagram #16, the water filter is part #3. Make sure it's not clogged, and if it is replace it with a good one.
Here is a blog on that website that discusses a similar problem, and may be of help:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23123-water-dispenser-not-working-ice-maker-does.html
Hope this helps, and good luck to you.
Oct 29, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Lights come on, not cooling, temp indicator shows (-)
Because your digital controls appear to be confused I think the electronic module behind the temp control is defective. The part number for your control board is 12868513
You can enter the model number JFC2087HRP in model and parts search feature at the link below. You may want to unplug refrigerator and examine the part for burn marks or other signs of damage. Let me know what you find, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Jenn-Air JFC2087HRP Side by Side...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Maytag PBF2253HEW temp control lights blinking
Your heading has two model #'s if your dealing with a PBF2253HEW you need a new jazz board pn W10165748 this part also controls your automatic defrost cycles if lights are flickering you should replace prior to something else going wrong
Apr 02, 2009 | Amana ARS2464B Side by Side Refrigerator
Control pad not working. Some lights are lit but
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Get me the make and model number so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Open Questions:
See all Maytag MFD2561KES Stainless Steel Bottom Freezer Questions
Maytag MFD2561KES Stainless Steel Bottom Freezer French Door Refrigerator Logo
157 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
