Question about Philips Televison & Video
Philps TV 42TA648BX/F7 shows error codes. 2 quick flashes and then one long steady flash.
MN 42TA648BX/F7 gives error codes and won't turn on or turns on but immediately turns off. Error codes are 2 quick flashes then one long steady flash.
aborcass
  • 2651 Answers
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Posted on Nov 17, 2008
SOURCE: WT 42311 won't power up
All that is wrong is the Convergence IS's. They are located on the deflection board (IC8C01 and IC8C02) and are mounted to a very large heat sink. They are black and are STK IC's, STK392-110. Replace both IC's with STK392-120 and you're in business. The -120's are and upgrade and have a higher amp rating. The IC's can be found anywhere on the internet for $9.99 and up. Check Electronix.com, MCM Electonics, Mat Electeonics for starters. Gook luck. Gary D.
Posted on Feb 08, 2009
drstrawn
  • 48 Answers
SOURCE: range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Posted on Mar 14, 2009
SOURCE: how do you turn the Ambilight on our philips tv?
Hi guys, I have the same model, and after reasing the manual a little closer and skimming the setup menu I've discovered that it's not actually a built in ambient light, it's actually a setting in the picture menu under "active control" that measures the ambient light in the room and adjusts the picture quality accordingly to ensure the best contrast and reduce glare/reflect imaging. Hope this helps....
Posted on Mar 22, 2009
SOURCE: giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
Posted on May 29, 2009
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
Security light flashes and won't start 02 lincoln ls
How old & what condition is the battery,on an LS
they only seen to last 4.5 years
Try only one Ford- approved PATS key that is programmed & you know has been working & nothing else nearby, such as a key chain
with other objects
Does the LED indicator flash rapidly or glow steady for 3 seconds,
with key in Run or Start ,if so, you got problems & will need a scan tool to get the codes,not a code reader.
Does the starter turn over the motor?
Need at least 2 keys programmed to system
You got at least 7 fuses to check on 2 of the 3
junction blocks (fuses)
Nov 14, 2012 | 2002 Lincoln LS
Philips 42PFL7603D/10 won't turn on flashes red 4 times slowly then red 6 times quickly
This is an indication of error codes for defects inside the TV. In order to ensure this is not caused by some erratic signal to system IC, switch off TV manually, Switch off power and remove plug and wait for 48 hours and retry. If it does not work even then, the TV might need service.
Aug 26, 2012 | Televison & Video
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
I have a Philpis 42" LCD TV Model # 42TA648BX/F7. Basically, I know the Power supply board is bad (it was not functional when I aquired)). Obviously someone previously had it diagnosed and got sticker...
Appears that the only other major component is the Servkit assembly
http://www.partstore.com/Model/Royal+Philips+Electronics/Philips/42TA648BXF7.aspx?SearchTerm=True
Sep 28, 2010 | Philips 42TA648BX 42 in. LCD TV
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
F7 error steady beeping
Nov 17, 2008 | GE JKP45 Electric Double Oven
Trinitron 36" led flashes 11 steady flashes then 5 quick.
Hi
You have defective power oscillation in power circuit! this need to diagnose to find the bad parts!
Thanks!
Oct 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
