Question about Dell OptiPlex 360 Desktop Computer
A light on the board but gx 360 cannot start - Dell OptiPlex 360 Desktop Computer
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 20, 2013
The space bar in a Brother GX-6750 typewriter is not working. How can I reset it or get it working again?
You must remove the case, then remove the key board, disassemble and clean it with alcohol .
DickyO
Sep 12, 2015 | Brother GX-6750 Electronic Typewriter
Where is the fuse on a Dell Optiplex gx 620 PC
The computer is receiving electrical power, but an internal power problem may exist,Ensure that the processor power cable is securely connected to the system board,.It sounds like it may have had a power surge and may have burned something in your board.. You could try removing RAM unhooking everything hard drive cd drive un plug machine, hold power button till you see the amber light go out. reverse installing everything after it has sat for awhile and try to reboot
Jan 17, 2013 | Dell OptiPlex GX620 PC Desktop
'03 lexus gx 470 door lights and dome are not lit
check fuses possable break power to ground in lighting circute
Jul 22, 2012 | Cars & Trucks
My Dell Optiplex Gx 620 isnt turning on..... No lights no sounds is it the motherboard
Bad power supply first, or just the switch. The mother board will keep it from posting, but lights should come on. a bad power supply or switch it will be dead like fred.
If your handy there are many tutorials on diagnosing a power supply on the internet. Usually when it is the mother board there will be a few beeps or flashing lights then a shut down, or frozen pc on boot then death.
But all these symptoms can come from a dead or dying power supply.
http://www.overclock.net/t/96712/how-to-jump-start-a-power-supply-psu-test-a-power-supply-and-components Do this at own risk..
Jul 07, 2012 | Computers & Internet
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
DELL OPTIPLEX GX 620 PC WONT SATRT ONLY ORANGE LIGHT KEEPS BLINKING
DELL OPTIPLEX GX 620 PC WILL NOT START.
ONLY ORANGE LIGHT.
Aug 31, 2010 | Dell OptiPlex GX620 PC Desktop
Three red lights
microsoft put out 360 consols flawed when they heat up the mother board flexes and the processor comes away from the mother board it has somthing 2 do with the brackets they used but u can buy a kit on e bay that u can do urself i got mine 4 £2.50 itis a new bracket with replacment screws and springsthat stops the board moving therfor holding the processor in place it also comes with instructions and they e mail a video showing how 2 do it i havnt done mine yet im waiting 4 the parts
Jul 28, 2008 | Microsoft Xbox 360 Core System Video Game...
Console starts up, games work, but controllers dont light up or work.
the controller board is bad, you can open it up and air it out and pray.
Dec 17, 2007 | Microsoft Xbox 360 Console
DESKTOP AMBER LIGHT ON
hi ,
could u please expalin or give details on your computer model ,make ??
As a Dell expert and from my exp these same problems are found in new dell desktop like gx 520,gx 620 machines..for further troubleshooting please let me know model??
Oct 25, 2007 | Computers & Internet
Dell OptiPlex 360 Desktop Computer   Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
