Question about MSI Ms-7529 V1.6 Motherboard Intel Lga775
Msi-7254 motherboard CPU Fan connection - MSI Ms-7529 V1.6 Motherboard Intel Lga775
Bubbabear64
  • 2794 Answers
SOURCE: msi pm8m3 -V H
Check the memory cards and see if there seated properly. Check your hard connections.
Posted on Jul 18, 2008
  • 2692 Answers
SOURCE: PC WON'T POWER UP
With nothing attached to the mother board except 1 stick of RAM in the first slot the power supply and monitor attached, and then  it still turns off ; I would make sure the heat sink was clean Reseat the Cpu and try it again. Now if the same results. I would attempt to substitute a different known good power supply. If that would not work, you are down to substituting a different CPU .
Posted on Dec 09, 2008
  • 14 Answers
SOURCE: msi and axper motherboards not powering up
How are you testing these boards? Have you completely installed them into the chassis, hooked up all the wires, attached all the components, put in all the cards, processor, HDD, etc.? If not, then I don't know what you think it's going to do otherwise. These boards need to be handled as minimally as possible to make sure they do NOT receive any static charge build up to damage any sensitive components. When a mobo powers up it performs a POST (Power On Self Test) and this includes a complete check to make sure that all the components are attached. If not, it shouldn't do anything. If it can't past POST, then it won't go to the BIOS, and in modern boards, cooling fans are controlled either by the BIOS or even the OS to adjust for cooling power and fan size/sound. More than likely, if your fan is turning on initially, it's just current coarsing through the board. When you attach the 4 pin connector it's trying to power up the board completely and the fan's wont run until they're controllers tell them to.
Posted on Jun 09, 2009
  • 86 Answers
SOURCE: MSI PM8M-V Motherboard cpu support
Hi There
The list of compatible processors is here:
http://global.msi.eu/index.php?v=1&func=prodcpusupport&prod_no=205&maincat_no=1&cat2_no=&cat3_no=#menu
The E5200 is a WolfDale processor and unsupported.
Many of the supported CPUs are hard to find but Newegg has one here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
Posted on Aug 29, 2009
Testimonial: "Thank you for information, JK"
  • 6 Answers
SOURCE: MSI K9N Neo
This board have some typical problems... Manufacture had used very cheep detals. So to repair this motherboard first of all you need to change transistors Q5, Q16, Q18 and micro scheme U18. If it will not help you , the last problem can be in south bridge, that you need to reball.
Sorry for bad English
Russia send you regards )))
Posted on Jun 04, 2010
MS-7297 Ver 2.1 Not booting: system fan not detected. I've bought in ebay a working msi mobo (so vendor says it works) that I can't boot because a message saying system fan not detected (bios...
you need the right heat sink for the cpu that you are using for the board check on board for cpu plug in, then plug the fan in make sure that you have enought heatsink paste on cpu not to much just enought to do the job. if that dose not do it then the board is bad.
Sep 24, 2013 | MSI Computers & Internet
MSI 845GVM-V (MS-7057-010) Motherboard cpu fan not ruuning but smps is ok when jpw1 is disconnected then fan is running but mother board is not on
Hello hare is the homepage:
http://www.msi.com/product/mb/845GVM-V.html#/?div=Manual
Try to download the manual, and check all your connections again.
Try also to renew the power supply.
Check also this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
The jpw1 is the main power connection for power to the cpu:
So you probably have a bad power supply.
Good luck
Jan 25, 2013 | Computers & Internet
WHEN JPW1 PORT I S CONNECTED THEN MOTHER BOARD CPU FAN IS JUST ON AND OFF WHAT IS THE SOLUTION OF THAT SMPS IS OK.
Good luck
Jan 25, 2013 | MSI 845GVM-V (MS-7057-010) Motherboard
Ram ok ,power sap ok ,lcd ok, cpu fan raning but no dimply, msi 7312 ver 1.0 plzz help
Hi, you can download a manual and drivers here:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Manual
You can add a AGP screen card if the onboard graphics
does not work.
Check the connections for the screen cable.
Try even with another monitor.
Sep 08, 2011 | MSI K9MM-V Motherboard
My cpu fan is working is now working,but when i look up to the BIOS set up the CPU fan system records 0rpm...how could this happen? is there other way how to fix it? pls help me.....tnx
Most likely its just the sensors; either they are not correctly connected, or not working, or the BIOS does not support them.
As long as the fan is running there should be no problem though.
May 10, 2011 | MSI 880GMAE45 AM3 AMD 880G USB 30 Micro...
I have this mobo (MS-7254) but i cant find anything about it
The MS-7254 motherboard was custom made by MSI for HP and shipped with the HP DX2200 desktop. Because it was custom made for HP it is not listed on the MSI site.
Here is a link to the support page for the DX2200 on HP's web site.
You will most of the boards specs there.
Click Here
Feb 23, 2009 | MSI MS-6580 Motherboard
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
Jan 07, 2009 | MSI K8MM3-V Motherboard
Msi pm8m3 -V H
Jul 18, 2008 | MSI PM8M-V Motherboard
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
MSI Ms-7529 V1.6 Motherboard Intel Lga775 Logo
63 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
